12-29-2013 12:56 PM - edited 12-29-2013 01:20 PM
I have a 24-70mm f/2.8L lens and am finding that it is not as sharp as i'd expect. I'm sure it's me and not the lens so hoping someone can help me understand what i'm doing or not doing correctly.
I'm attaching a picture as an example...hand held...here are the settings:
EF24-70mm f/2.8L II USM
59.0mm
1/640 sec; f/2.8; ISO 400
Shutter priority; Spot metering
shot with 70D
when you zoom into the tree it is cleary not in focus/sharp ;(
I've tried at differen shutter speeds but still having the same issue... going to try different apertures next...
01-02-2014 07:42 PM
01-02-2014 08:03 PM - edited 02-21-2014 09:20 AM
OK, I am so glad you got another's opinion. I am so glad and not unexpectedly, the 24-70mm f2.8 is good.
But I disagree on the keeper rate. If I shot with the same expectations as he gave you, I would be out of business in short order.
As I told you way back I am not a fan of any of the xxD cameras. But in your case I believe some OTJT is in order. Go out and use it. Shoot a lot. Shoot everything. Learn that system and you will be fine.
01-03-2014 09:14 AM
01-03-2014 09:22 AM
01-03-2014 10:12 AM
This is my personal preference and not based on the written specs.
But I wouldn't buy either, a 6D and/or a 70D. However, if given the choice I would go for the 6D in a heartbeat. As stated I am not a fan of any of the xxD cameras. I am not a big fan of the 6D either mainly because it has features I don't have need for and the biggest deal breaker, it is not a 5D.
Now this is me but I would prefer a good used 5D Mk II over either the 70D or 6D.
For you, however, the 6D is full frame and is going to open a whole new world for you. The 6D is Canon's idea of an enthusiasts level full frame camera, essentially a APS-C full frame version.
Bottom line, a 6D is a 70D in full frame clothes!
01-03-2014 11:34 AM
Thanks again.... any idea if my Sigma AF 70-300mm f/4-5.6 APO DG Macro for Canon will work on the 6D?
01-03-2014 01:28 PM
Just checked - it will 😉
01-03-2014 05:37 PM
In Sigma the DC designation means APS-C and DG means FF.
01-09-2014 09:16 PM
01-11-2014 08:02 PM
