Search instead for
Need advice on protective filter and lens hood
shorty1
Occasional Contributor
I am looking into purchasing a UV filter to protect my 18-135mm IS USM lens. Is the B+W 67mm UV Haze MRC 010M Filter a good filter to use if I would like to keep the filter on all of the time? Would a standard lens cap fit on top of this?
Is the Canon EW-73D lens hood a good lens hood to use on top of the Canon 18-135mm lens?
RobertTheFat
Honored Contributor
B+W filters are excellent but expensive.
Most in this forum would probably say that you don't need a protective filter, especially if you're using a lens hood. I think I fall into that category, though I did once try to nibble while covering an event that had a buffet table, and stuck the end of my lens into a dish of sour cream dip.
There's no such thing as a good or bad Canon hood for one of their lenses, just the right one or a wrong one. Always use the one they recommend, or it may interfere with the field of view. Lens hoods typically have very close tolerances in that respect. If you use a 3rd-party hood, make sure it's an exact replacement for the correct Canon hood.
Bob
20 REPLIES 20
Bob from Boston,
Not every couple years?
"Lots better than cleaning the mist off every couple minutes ..."
