05-05-2024 04:01 AM
I have the Canon EF 70-200mm f/2.8L is III on a EOS R using the mount adaptor. I'm looking to get a teleconvertor to get a little more reach for some high school sports photography. I'm seeing some used MKII 1.4x teleconvertors on the market for less than half the price of used MKIIIs. Any real big or noticeable benefit to going with the MKIII versus the MKII?
05-05-2024 04:35 AM
Welcome to the forum.
Here is a comprehensive discussion of the Version III and a comparison with the Version II.
Canon EF 1.4x III Extender Review (the-digital-picture.com)
05-06-2024 11:42 AM
Thanks for the info. I've read a lot of different comparisons and reviews, but most seemed to be focused comparing the two teleconvertors on an older MKI or MKII lenses. I haven't seen anything specific to using on a MKIII lens.
05-06-2024 11:58 AM
The optical system of the two lenses are the same. Difference is a newer paint color and flourine coating on lens surfaces.
Reviews of the TCs were published when the devices were released. At that time the V2 lens was current.
05-05-2024 11:04 AM
I wouldn't buy either until you try DPP4. You can d/l it free from the Canon web site. With DPP4 and shooting raw you can edit and crop your images perhaps as well as what a tel-con con offer. If you still want more buy the tele adapter afterwards. Did I mention DPP4 is free and you won't give up a stop on your lens.
05-06-2024 11:43 AM
Thanks. I've haven't heard of that before. I'll check it out as well.
05-07-2024 11:20 AM
The other most important part is to always use raw. If you get DPP4 and use it to u/l to your computer the raw conversion is automatic so you will not see any difference in how you get images on the computer. In fact it is pretty easy and simple and automatic.
