11-15-2022 03:02 PM
win11 recognizes mx922 printer. says i need a driver. tried to install driver from canon, but it does not complete. says it cannot detect printer. i can print fine from my phone to the mx922 printer using the wireless LAN. any help would be appreciated.
12-08-2022 02:35 PM
SUCCESS!!!!! I plugged in the Ethernet cable between the MX922 and my modem/router. added device MX922 in Win11 and was successful! Printed sample document and was successful!
11-16-2022 03:33 PM
Hi jacksplake,
Please follow these steps:
1. Please press the MENU button on your PIXMA MX922
2. Use the down arrow to select the wrench and screwdriver icon and press OK
3. Use the left arrow to select Device Settings and press OK
4. Use the down arrow to select LAN settings and press OK
5. Use the down arrow to select Confirm LAN settings and press OK
6. Select WLAN setting list and press OK
Please view the name listed next to SSID. Please make sure that your Windows 11 computer is connected to that same network.
Using the down arrow, write down the IPv4 Address and follow these steps:
1. On your computer, please press the Windows key on your keyboard and the letter R, then let both go
2. In the Run window that appears, please type CMD and click OK
3. In the Command Prompt window that appears, please type:
PING and the IP address you wrote down. For example if you write 192.168.1.4, you would type:
PING 192.168.1.4
and then press the Enter key on your keyboard
Did you get:
A - Timed out
B - Destination host unreachable
C - Sent = 4, Received = 4, Lost = 0
11-17-2022 11:52 AM
the ping result was 'C'.
11-29-2022 05:31 PM
driver install retried and magically it installed.... but attempted print fails and also the test file will not print. Troubleshooter could not identify the problem. not sure how to proceed. Any further help would be appreciated. Thanks!
12-01-2022 08:48 AM
Hi jacksplake,
Reinstalling will resolve this issue. To do this, please follow these steps:
1. Press the Windows key on your keyboard and the letter R, then let both go.
2. In the Run window, please type CONTROL PANEL and click OK.
3. Click on View devices and printers (or Devices and printers, depending on your view).
4. Right click the Canon MX920 series and left click on Remove device. Repeat until all MX920's are removed.
5. Click 1 time on one of the other printers installed.
6. At the top, click on Print Server Properties.
7. Click on the Driver tab.
8. Click on the MX920 in the list. Click the Remove button at the bottom.
9. Choose Remove driver and driver package and click OK.
10. Click Yes and then Delete.
11. Repeat until all MX920s are removed from the list.
12. Click Close to close that window.
13. In the upper left corner, click on Control Panel (or the Back button).
14. In Control Panel, click on Uninstall a program (or Programs and features, depending on your view).
15. Click once on "Canon MX920 series MP Drivers" and then click Uninstall at the top.
16. Follow the on screen prompts to uninstall the driver. When you click Complete, the driver is uninstalled.
17. Once done, please reboot your computer.
When your computer restarts, we will reinstall:
1. Please use the following link:
https://www.usa.canon.com/support/p/pixma-mx920-mx922#DOWNLOADS
2. Click on "Software & Drivers".
3. Click the Download button next to "MX920 series MP Drivers Ver.1.01 (Windows)".
4. Once the download is complete, open your downloads folder. To access this, press CTRL and J, then let both go.
5. Double click "mp68-win-mx920-1_01-ea32_2.exe" to begin the installation.
6. Follow the on screen prompts to reinstall.
Once the installation has completed, please attempt to print.
12-01-2022 01:37 PM
Back to square 1. Thanks for the detailed procedure on uninstalling and reinstalling; everything went well except the driver still would not install. When trying to install the driver, i received the Error message: Printer could not be detected in the network. (WLAN). checked the printer WLAN settings; Ipv4 address is 192.168.0.24. I pinged that address and all packets were sent and received OK. I have 2 android phones that print on my MX922 ok. I have another win11 laptop that also prints there ok.
12-08-2022 02:35 PM
09/26/2023: New firmware updates are available.
CN-E45-135mm T 2.4 L F - Version 1.4.0
EOS 1DX Mark III - Version 1.8.0
08/18/2023: Canon EOS R5 C training series is released.
