09-04-2020 05:32 PM
I too have the b200 error, and have tried most of the forum and u-tube tricks to get it going. I must have the Cleanest print head in the USA. Where is the source document that says B200 is a print head error ? Cannon is verry stingy with service info.
09-05-2020 08:46 AM - edited 09-05-2020 08:49 AM
Both of which point to the same KB article.
Unfortunately, there is no solution to this error. Your printer will require service or replacement.
09-05-2020 04:03 PM
shadowsports: Thanks Rick. I found the second source, but it was a short version advising to send it in for repair. With new mx922 going for $400. +or - $50. I guess I'm going shopping
10-07-2020 02:29 AM
over the past few years I have always been able to circumvent the B200 error with the techniques here and elsewhere but might have taken multiple attempts.
This time I have not been able to clear the error after about two dozen attempts and different combination of techniques.
When the B200 occured this time I was low on colored ink so I switched all three colors to a freshly refilled set. Three prints in a row came out sepia colored. I put the other three colors back in and got a great print. I took the three back to have them flushed and filled for free and had the other set filled too. I have had the B200 ever since. I just swaped all five inks and still have the B200. Seems that the B200 is a refill issue at this point. What ever the cause, printer is junk to me now.
10-07-2020 03:00 AM
I also want to say that that once the print command is sent and the printer starts processing the job and just about when you think the print should start coming out is when the B200 shows up. Again all that wasted time. If it has a B200 error we should not even be able to send it a print job. I got B200, your not allowed to print. really frustrating. The print head does not communicate with what? I had a great photo print before I change the ink one last time.
10-07-2020 10:10 AM
Thanks Needafix. I wish canon could provide a real service manual so that we consumers might have a chance at getting printing again. I wonder if canon has a real manual available to the printer repair shops? Or have the shops just become staffed with "remove and replace" mechanics ? I did buy a canon tr4520in order to keep printing , but it is nowhere near the machine the mx 922 is.
