how do i intergrate my smartphone to my printer
how do i get my i phone samsung to work with my printer ?
I have a PIXMA MX 492 Printer & Scanner. I am using a Macbook Pro OS X El Capitan Version 10.11.6 I downloaded the Canon IJ Scan Utility2 driver from the Canon website. A problem arises when I have a filename to an item I want to scan. For example i...
I have tried with an MG2120 and a brand new MG3620 with Windows 10 and what shows up as teal on the screen prints blue. It is a file that someone else sent when we ordered teal so I don't think the monitor is off.
I have a Macbook Pro and just downloaded the new El Capitan. I couldn't get my wireless 3120 to print for a long time. I downloaded the driver again, reset the wireless a dozen times, and fiddled around with it for days and finally got it to print!...
When I print a picture that has any black in it, the black contains lines 1/4 inch apart. All other colors print just fine. I have replaced all ink cartidges with Canon brand. The printer is less than 1 year old and has done this since day 1. I h...
I have rebooted, reinstalled ink cartridges, replaced ink cartridges several times, no change to warning lights. There is no paper jammed in the machine. My laptop sees the printer as normal. anything else I can do? thanks J
MG6220 will print wirelessly but the scanner won't work. I get the following error message: Cannot scan for these reasons:-Scanner is turned off.-USB cable is disconnected Please check and try againScanner driver will be closed. Code:5,156,61 Window...
My Pixma MP640 tells me two cartridges I have just put in are not installed properly. But they are in properly.My iMac went in for repair and since getting it back, I have restored from Time Machine. I am wondering if it has downloaded an updated pri...
Does anyone know if it's possible to print multiple DL envelopes for a PIXMA MX726? The manual I downloaded does not appear to mention it. Cheers
Please help My Canon MX922 has been working great until yesterday when it started having this printing issues. When I attempt to print a picture or a document there are strange gaps. I attempted to align the cartridges clean the rollers but neither...
I'm trying to scan on my MX410 connected via usb to an Apple Desktop, it worked fine earlier today and then all of a sudden I'm getting a message PC scan standby and then anotther message wait a little while?
MY MX920 printer keeps printing the same page over and over
Hello, my Pixma MG7720 can no longer do borderless printing correctly. Im running Windows 10 and use Photoshop to print. Ive been using the same settings I used before but now it seems to leave a thin white line on the left side after printing. It al...
I have a Canon iP8750. It is less than 2 years old. Some lines of black text are appearing blurred: line one is sharp, lines 2, 3 and 4 are blurred, line 5 is sharp and so on. I have:cleaned the nozzels, replaced the cartridges with Canon and non-Can...
Hi I have a MG5650 printer / scanner at home and another at work. My home (family) laptop is not connecting the MG5650 at home. My work laptop is connecting to both MG5650 printers. The home laptop did once work, then did not. It might have coincid...
Subject | Author | Posted |
04-28-2024 12:33 PM | ||
04-27-2024 04:40 PM | ||
04-25-2024 07:00 PM | ||
04-25-2024 03:03 PM | ||
04-25-2024 05:02 AM |
