Scanner error
My printer/scanner made an error when i wanted to scanIt said that i had to set the scanner settings on the computerbut the computer said the oppsite. I dont know what to do now. And the canon support doenst help me eather
The message pops out when I was trying to print out.What should I do?
I am unable to reset the Black Ink Level. None of my printing is working. The popup when I print mentions going to the Cartridge Settings on the Maintenance tab, but there is no Cartridge Settings option there. I've also tried to hold the STOP butto...
The model is a mg4220. I have run it thru the cleaning maintenence but no help.
I'm having the same issue with the same exact printer. I use the canon ink for my printer. I changed the large black ink a few days ago because it was low and now my printer won't print ink on the paper when I print.. I've physicially cleaned where t...
Hello i need help with my MP280 printer, i just purchased it and i tried to print something for the first time today and it tells me that it is printing but when it comes out there is not anything actually printed on the paper. I tried alighning the ...
This machine has got to be like the worst machine ever made by Canon. It never ever wants to print even just the most basic stuff. It frustrates me how it can literally take 30 minutes before this freaking thing wants to work. So the issue is that wh...
The option to select two sided printing is greyed out on my iMac for my iP7260, how can I change this?
My MX860 is connected via WLAN to the home network. In the last two days the print dialog pops up indicating "Creating Print Data" there is a progress bar that does not appear to get anywhere. After a while (longer than usual) the printer wakes up...
I have the MG 2120.On every other printer I've used when you wanted to print an envelope you just push the one glide closing to the other glide..On this printer when you push one side of the glide the other side comes too placing the envelope in the ...
I have cleaned the ink head or whatever, I've done the maintenance via the printer itself and nothing. The paper goes through and it sounds like it's printing but the page is blank. Help! I'm now working on a deadline.susie
Printing - on "Page Setup" I changed the number of copies per page to 2; and I am unable to change it back to 1 copy per page. On the drop down menu (Specify) there are choices of 2, 4, 6 etc but no 1 copy per page available. I tried using default ...
We just set up our printer the other night, but we've had it for a while. It was taken out of the box before we moved houses and we've lost the manual to it. I was able to connect to the Wi-Fi router using an online manual, but now I'm lost.Is there ...
I have a Canon MG4250 which is displaying the error message 1303 (Paper Jam) I have followed all the instructions and am sure that there is no paper jammed. I am assured that according to the great God Google this can be a false error message which ...
Hello, I have a Pixmaix6820 that doesnt print the full image. I'm running it on a MAC (Sierra) and trying to print on kodak glossy photopaper. Everytime I print, the image is scaled up and have all the edges cut off for some reason. The 'scale to fi...
Subject | Author | Posted |
04-20-2024 05:42 AM | ||
04-19-2024 10:03 PM | ||
04-19-2024 07:20 PM | ||
04-19-2024 03:01 PM | ||
04-19-2024 12:24 PM |
