Image Garden not showing Scan Facility on MG6250
Recently changed from windows to Macbook OS Sierra. Using wifi I can print but cannot see Scan facility
I get an error message trying to scan from the feeder of glass:"A scanner driver supporting this software is not installed. Install it and try again.Code:14,230,1I re-installed the software on the CD and from the web. Same problem.I never had this pr...
I have an imageclass mf 4880dw. when I scan wirelessly i almost always get the error code 155,0,0. I would say this happens about 75% of the time but sometimes it works without me doing anything else. I've reinstalled the drivers, etc. and my interne...
Forgive my ignorance but I set up the printer last night and printed some lovely work from my documents. Today I want to print off some bank statement and nothing happens? Internet connection is fine, I am clicking on the Cannon printer option and n...
My Pixma MG6320 printer no longer supports duplex (2-sided printing) from my iMac desktop when printing from Safari. I had just upgraded the iOS from Maverick to Sierra, so I assumed Safari was also upgraded. I am now using Safari 10.1.1 with the Can...
I just replaced ink and have error 1750. All cartridges are full. I did use the reset button however when I try to print I get message Cannon MG6800 series Check the printer for errors. Please help. Thank you.
I am getting B200 error code on my MG5520. I have tried "the open cover and let print header travel almost halfway and then close the cover" to get the priner to start. I can then scan, but I cannot print. If I try to print, I either get the B200 err...
I have a Canon Image class MF4570dn printer/scanner that will not scan - it did scan up to a few weeks ago and i can't figure out what is wrong - I have shut it down and checked all the cables. I am working on windows 7 Professional - when I try sca...
Starts to print but cuts out before completing cycles.
I've had my printer for several years. Never had a problem. Today it won't turn on. Unplugged it plugged it back in nothing. No code. Changed it to a different outlet. Nothing. I've read other comments about this printer with this same issue ...
Just bought a new Pixma MX 922 to replace my old dead HP C7280. Tried to copy a single sheet, but it kept spewing out multiple copies until I hit the stop button. Yes, my printer properties is set to (1) copy.Next, I tried the doc feeder to print a...
I load the paper in the rear tray and print; the printer starts the setup to print, where it draws in the paper by about two inches, moves the printer head in the correct location and gets ready to print but then says please load paper. I did a deep ...
Also can my printer take XL ink cartridges?
Hello,i dont know if this is the right forum or if anyone came across this issue but i have a canon selphy cp810 connected to AC power and it keeps telling me "low battery".Thing is, i cant print anything because when i try to, i always get the messa...
Some time ago my printer pixma MG4250 begun to print in a greenish color for black & white documents.To print I select option to print in grayscale but the results are greenish color, my cartridges are quite new and I have the printer installed in xu...
Subject | Author | Posted |
05-26-2024 09:55 AM | ||
05-26-2024 01:12 AM | ||
05-25-2024 02:38 PM | ||
05-25-2024 02:14 PM | ||
05-25-2024 01:41 AM |
