Error U051
I have just replaced the Black Ink Cartridge on a Pixma MX410 and I keep getting the U051 Message. It is the right cartridge, How do I fix this? Thank you..
Pixma MP 282 .Since replacing the colour cartridge , yellow has become pink : is this the fault of the - non-Canon - cartridge ? C.C .UK
Hello, My problems are ONLY the printing of PICTURES, as the regular document printing is working fine. I have checked the ink tanks numerous times, did all the tools Cleaning, Deep Cleaning, Head alignment, Nozzle check, etc. When I attempt to...
Hi,I cannot install a driver to my printer.I have tryed manytimes with it seemingly to be a succesful install only to have a driver error pop up Do these printer just come to lifes end like this.It has wored flawlessly since the begining so i was won...
my MG7520 makes two scan copies automatically. How to I get to make only one copy
in this day and age, you would think a company would make sure all flavors are going to work. Either this was not a use case, or QA didn't test. WHen will the scanning IJ Utility work on the Windows 10 64-bit ?
mp 600 alternately prints 4 lines and then skips 4 lines over and over again in a document when printing in black ink.
Hello,I just purchased a TS8151 printer. I have an older mac laptop with OS 10.6.8. I didn't find a driver for my Mac, so I connected to the printer via Google print. I'm able to print from my phone and ipad, but when I send to print from my laptop i...
I bought the MX922 because I needed a printer under 18" deep, and the specs on the MX922 say it's 15.6" deep. But when I print, the output tray (the door on the front) drops down, increasing the depth to something like 22". In the tight space I hav...
I am a senior, I have had other printers, but can't seem to figure out how to scan. My MG3220 can't find a bookleton it. Where or what do I do to get help. Thanks. This is wirless to my laptop...Dell
I recently did a system restore, and now I cannot install the mp drivers for my mx430 printer. I have tried installing from both the disc and from the canon website, and have also tried both wirelessly and using the USB connection. The printer is con...
I am looking everywhere for where the scanner button is. When I press the black or color button, it prints what is sitting on the scan bed instead of scanning it. The whole reason why I bought this model was because it is supposed to scan. Can you ...
This is SO F'n irritating. I have the Canon MX870 and ONLY use genuine Canon ink. I keep getting an error message that the smaller ink cartridge 221 (on left most position) is not recognized. WTH. I only have one printer. Any help would be most a...
I bought the TS6000 and i was wondering if anyone knows if i can print with cardstock and vinyl?
I took the case off my IP1700 to clean the ink absorber, reassembled and reset the ink absorber message. Now when I try to print a one page test document it will quickly feed one sheet of paper through and out of the printer then feed another sheet ...
Subject | Author | Posted |
05-18-2024 12:39 PM | ||
05-18-2024 12:54 AM | ||
05-17-2024 10:43 AM | ||
05-16-2024 08:44 PM | ||
05-16-2024 12:18 PM |
