Canon MX439 drivers
Hello,I have a new computer and no longer have the CDs, is there another way for me to install everything? i have been able to print but cannot scan. thank you! I have a canon MX 439 Pixma and have Windows 8
New computer and I don't have original disk for MX870. I want to load the Canon Solutions Menu. When I go to the MX870 Page I find:Drivers: 2 different drivers I could download but i don't want a printer driverManuals: I find some manuals and optiona...
Hi all. I have a Canon MP280 Pixma, and everything I scan comes out upside down and backward. I installed the latest driver and scanned again, and it is still coming out upside down and backward. Yes, I have some photo-editing software I can fix it w...
Is it possible to force the printer to print balck and white from the smaller black ink cartridge when the large black ink cartridge is empty? I've got 4 new small (BK 221) cartridges to use. The larger black cartridge (PGBK 220) is empty and the p...
Hi. Out of nowhere I'm getting this error message: Support Code : B200 An error has occurred. The printer needs repair. Turn the printer off and unplug the power cord of the printer from the power supply. Then see the manual and contact the servic...
I've had my PIXMA 922 for about two years, using WIN 10 and the "Print Preview" is always a valuable tool. Recently (last month) the "Print Preview" window gets bypassed and the printer just goes straight to printing, although it's still in my settin...
Every time I try to realign my cartridges, I get a P 02 error every time I print the alignment sheet. This only happens during alignment. Everything else, no error. The print comes out a bit ugly because it's not aligned but it still doesn't stop fro...
I had a complete Windows crash and had to reinstall it from start. When I tried to install the drivers for my Canon G6620, which worked perfectly fine before the crash, it hangs up.First, even though my printer is turned on, it stops and tells me to ...
Hello, I have a Canon PIXMA MG3500 series printer. I understand that there are two models but I am unable to locate the model number (it is not anywhere on the printer), but I hope you can help me regardless. I have a color cartridge and black & whit...
How can i find my canon printer model name to download drivers and installer just by using the serial number, serial number is **Serial number removed per forum guidelines**THANK YOU
I have a TS3122 printer that printed 2 pages, started making a gear skipping sound, and now the oarnge lightning bolt error light on printer, is on. I have cycled the power, andput in new paper. Its like the end stop sensor isnt working anymore, so i...
HI, I inserted a new ink cassette a few days ago (2nd one I use) and it started making weird paper sounds. I ignored it, but now it is stuck. I tried to open it but it doesn't work, I managed to get part of the cassette out but the ink paper is stuck...
I have error occuir in my printer canon pixma mg5570 it says 'printer error has occured, Contact the service center. support code 5B00, is there a way i can fix this by my self,please help me thanks.....
OK, I read on another site that turning off the Thumnail View in ScanGear lets you adjust the input cropping for the slides. Yay! But it does not seem to remember these settings, even if i save them to a new profile. Am I doing something wrong or is ...
Please help. This is a new printer and new computer. It was working but all of sudden said to check connection. I uninstalled the printer from my computer and reset the printer. Both are hooked up to the WIFI but neither my mobile device or my comput...
Subject | Author | Posted |
06-11-2024 10:55 PM | ||
06-11-2024 09:39 AM | ||
06-10-2024 01:50 PM | ||
06-09-2024 10:48 PM | ||
06-08-2024 08:26 AM |
