Desktop Inkjet Printers
PIXMA TR4522
I have only used this printer a few times and only printed out about 30 items. I am now getting an error message with code number 1303 paper jammed in machine. I have checked everywhere and there is not a piece of paper or even a shred of paper anywh...
scanning documents to an email list?
I set up an email agroup in Outlook and I'm trying to test it by scanning a document to the email address for that group.  The scan to my individual email address works, but when I scan the same document to the group email address it doesn't go throu...
I squirted ink through the hole
To save money, I drilled holes in the see-through ink containers in my Canon 5700 series printer. This resulted in plenty of warning messages that finally allowed me to disable the ink level warnings.  I then drilled holes in the nearly empty ink wel...
standard by Apprentice
  • 1826 Views
  • 2 replies
iP7220 Print Failure
My faithful Canon iP7220 Printer suddenly started to misprint.  All colors except BLACK print perfectly. New BLACK cardridge did not fix problem. Problem is: On text print out characters are duplicated a small fraction of an inch apart horizontally  ...
haasent by Apprentice
  • 1494 Views
  • 2 replies
MG5722 connected to router issue with faxes
Hello - I am hoping someone can help me.  I have a router Asus and I have the printer plugged int the router - rather than just a direct printer connection.  I did not use the canon setup and instead set it up as an LPR server. I am able to print jus...
ChelChel by Apprentice
  • 1127 Views
  • 0 replies
MG 6250 won't print on cd
Hi All...happy Friday! My MG 6250 won't print on to a blank cd (has done fine in the past) goes through the motions but when cd comes out, it's blank!Docs print fine. Any sugestions? Thanks in advance. S
sj3 by Apprentice
  • 1676 Views
Unanswered Topics
