Set the pc to start scanning
Since we started using our new windows 10 computer we can no longer scan a document without seeing the message set the pc to start scanning, how can I fix this?
My MX922 has lost its mind. When helping my daughter print something from Google Docs, we found using the high quality print setting was still returning a bad result. I ran the nozzle test and it seems to be missing the pattern at the top. I then ...
Does anyone know how to fix this problem. I deleted the app and reinstalled it. Same message.
The printer requsted to update. I agreed and now I have a blank screnn and a flashing power button light. If I unplug, it begins the update and then say "failed update press start button to try again"
how do I prevent the scanning software from adding the date to the saved file name every time?
HiI hace my iP7250 for couple years and today Ive got this message Support Code 1403... tried couple things and read couple messages but nothing worked.Is there an "official" way of sorting this for this model?Thanks!!p
I need to scan several documents,and put them into one folder.Can the folder be sent as an attachment.
My TR8520 printer makes loud clicking sounds when the print heads cycle. Also it will not print color. No error codes showing. Roger
Hi there, For some reason when I try and print in A3, and set the layout as a3 the document still prints in a4 size onto the a3 paper. I have tried various ways around this, using a different programme ( have tried in adobe illustrator, google docs, ...
Hallo, I do have a Pixma TS5050, using Windows 10The printer works without any problems, wirelesscopy function is fine, too It does not scan! I receive Code 5,157,69 Somewhere here I read that disabeling VPN was the solution. I'm not aware of having ...
Trying to print on printable DVD. I've reloaded all the Canon drives, Powered on/off, reset, reinstalled the Easy Photo, Easy Photo Editer, the kitchen sink, as well as the dishwasher, on both my mac laptop and the imac. I hesitate buying other softw...
My all-in-one: Pixma MX870I know how to darken a copy being made. But I don't know how to darken scans made through the Navigator software. Many of my scans are much too light. How can I darken scans?
I have a MG 3022, I've been trying to set for half an hour now. The problem is that the printer won't let me do anything due to some "error," it blinks three times and the pauses. I searched up the pattern and have learned that this message will disp...
Operating system: Windows 10; MX922 connectedto computer via USB cord.Printer started normal printing a card (done many times before).Printer stopped printing in middle of job; some ink being low, I stopped the program and replaced the cartridges. W...
Subject | Author | Posted |
04-19-2024 03:01 PM | ||
04-19-2024 12:24 PM | ||
04-17-2024 04:26 PM | ||
04-16-2024 09:57 AM | ||
04-15-2024 09:38 PM |
