Desktop Inkjet Printers
MX925 cleaning too much
My MX925 printer is now cleaning every time it is turned on and after every time it prints, i.e. I can print sometihing every five minutes or so and it cleans after every one. I am sure it did not do this much, maybe every ten prints, it is wasting s...
MikeR1 by Apprentice
  • 727 Views
  • 0 replies
Pixma IP8750 cannot load MP 101 matte paper
I tried using a Canon mp 101 matte paper to print. First, the positioning mechanism in not able to load a single sheet and throws a no paper in tray error. I adjusted it manually for the printer to load. After that, the printer starts printing but th...
Rupert by Apprentice
  • 2833 Views
  • 2 replies
Canon G1000 Megatank
Jeffzilla Jeffzilla New Contributor9:43 AMHaving an issue with the G1000 printer. Solid black areas are printing in gray and black stripes. Other colors are doing it but not nearly as bad. I ran all of the system cleaning procedures. Nozzle check pri...
PIXMA G6020 not printing well
Hello, I am having trouble getting a good print quality from my PIXMA G6020 printer. It comes out faded and fuzzy. I have tried running the cleaning cycles, the deep cleaning cycles, doing a nozzle check, and a head alignment. Nothing that I do seems...
jlmaitri by Apprentice
  • 5629 Views
  • 4 replies
Resolved! ts8100 series (model ts8120) how to set up WiFi
Windows 10. I previously had the printer set up for WiFi. To troubleshoot an issue with another printer, an HP not Canon, they asked me to remove the 8100. Now I've finished that troubleshooting and cannot get the 8100 to use WiFi. I have it connecte...
MX870 misalignment -- black only
My MX870 has suddenly developed a strange misalignment problem. Printing is shifting left and right every 13.57mm. That is to say, a vertical line will print 13.57mm down, then shift 0.5mm left for the next 13.57mm then back to the original position ...
torch by Apprentice
  • 1699 Views
Error code 5 157 69
Hello! My pronter has stopped working. I am getting an error code as listed above, with the very common, LAN not connected, etc. even though it is. I have a Pixma MX 722 and am running Windows 7. And I live in Canada, if that matters. Thanks for the ...
Canon iP2770 prints in weird color
Hello, I'm new here anyways.I'm here to ask on how do I fix the printer printing in weird color?It prints purple even though I did all the cleaning and refilling the ink.I had looked inside the printer by opening the cover thing but nothing seems to ...
TF21045 by Apprentice
  • 7188 Views
  • 6 replies
Basic question from a newby...
I have a PIXMA MG7720.   I've used it since 6/17,  with no problems. I'm not a heavy printer user The other day, out of the blue, I get Support code 1256, and it tells me to open the paper output tray.  When I do this, it says "an error has occurred"...
dennism by Contributor
  • 1460 Views
  • 3 replies
Canon TS8220 not printing on glossy
Tried to print on glossy paper. Each time the color is totally faded. I tried printing on regular plain paper and it's fine. I have cleaned the print heads, nozzle heads etc. I have added new ink. I have even tried to print from the printer itself wi...
VicMar by Contributor
  • 2247 Views
  • 6 replies
Printer MG6600 - Printing color broken lines
Hello Friends,Hope you all are doing great !!My every fully functinoing Canon MG6600 has recently started to give problems in printing, since i bought it 4 years ago.All of a sudden, since a month, it has started to print broken color lines instead o...
