MX922 no longer printing black
I have demonstrated, changed cartridge, turned off and on. Still no black.What am I missing?
Our MX922 was previously connected directly between a phone jack and phone/answering machine combination. However, that phone line was associated with a home business which has closed, and the dedicated phone line for it has been disconnected. We wan...
I noticed that when my laptop is connected to my home network wirelessly, the laptop finds my Canon MX490 printer and I'm able to print to it and scan documents. However, whenever I connect the network cable to my laptop so that my laptop is now on w...
I just recently picked up the printer, and I have the 281 ink (blk/c/y/m), and when I start it up and it goes through the language selection then how to install the ink, I put in the 4 ink cartridges into the correct slots; it still keeps staying on...
I installed a new PIXMA TS5120 on a new Windows 10 laptop and I have a reoccurring error of 'Printer not responding' with document trapped in the print spooler. Same problem occurred with working Pixma TS3122 installed into the same new Windows 10 la...
Hi there, I made a clean install and downloaded fresh drivers and software for catalina Despite this th emac doesn't recognize the scan:- it doesn't recognize the scan using IJ scan utilities- it doesn't appear in solution menu (hopefully yes afterrw...
I recently installed the Pixma TR7550 along with the full set of drivers which include the IJ Scanning utility. The printer is connected to my Windows 7 machine by a USB cable and works fine but when I run the scanning utity I get this message: Cann...
Hi,I have a Pixma MG4150 which had a blank 6mm wide area the length of the paper.I have cleaned and deep cleaned and fitted new cartridges with no change.Could someone advise me please? I thought the print head being fitted to the cartridge would mak...
I started doing the setup online and saw that a bunch of picture and photo tools was going to come with the download, so I quickly cancelled it and went over to your Drivers page to see if I could get the lean-and-mean driver-only download. I found i...
I typically print black ink shipping labels, but lately my mx452 has been printing very light (can hardly read the writing) and printing a light blue/green color even when selecting black/white. I've had the printer several years and this is the firs...
I snet a print command to my MX892 and it went through all the commands but did not print, tried coping a document and this did not print. never happened before what's the problem.
I bought a new Canon TS 8351 on 25th November last year. I bought it because my old reliable Epson Stylus Photo RX620 no longer recognised Windows 10 on my new laptop, so the functions were limited and Epson were no help. This new printer doesn't ...
I replaced an MG6500 series inkjet with a TR8520 and after the install I deleted the drivers for the old printer. Apparently the driver used by the scanner XP.com got deleted also, and now my scanner on the new printer won't work. I tried reinstallin...
hello please reply me as possiblei had bought a set of refillable ink from ali expresseven before filling it it was okay when i had put in my printerafter filling the black ink the big one the ink was coming out while i was refilling it i stopped put...
Hello, im wondering if anyone has tried making the ip4000 wireless with a USB WiFi or Bluetooth dongle, and if so, what model - and how's it do? Theres no SD card slot on this printer (and the USB port may only be for a flash drive - but I don't know...
Subject | Author | Posted |
04-28-2024 12:33 PM | ||
04-27-2024 04:40 PM | ||
04-25-2024 07:00 PM | ||
04-25-2024 03:03 PM | ||
04-25-2024 05:02 AM |
