Ink expiration date
Hi, How can I tell what the expiration date is on my ink cartridge?Thank you
I have a TS3522 printer. Compared to my old 1980 printer this one uses ink very quickly and I seldom print. I purchased it last October and have replaced cartridges at least 4x. Anyone else have this issue? Also seems to grab several sheets at a time...
Hi Folks. I have a Canon G4210 printer operating off a MAC Catalina operating system. The G4210 Nozzle Check Pattern is starting to have black printing issues. When I print a Nozzle Check Pattern, I notice two problems with the black section. The fir...
I have had a MX490 for awhile now and never had an issue with it. Recently the black ink went low, replaced it....and now it won't print black ink. I've cleaned it, deep cleaned the nozzles, print head alignment, cleaned the whole printer out with ai...
Help please I just purchased a New Dell Desktop and my TR8620 prints fine but it will not scan. Does Window 11 not work with this printer? Or do I need to do something else? I followed the Cannon set up completely online Thank you in advance
I am using canon Pixma e4570 it print blue instead of black also there is gap in printing and in last it released paper without printing. I also changed the cartage with the new but same problem
Hello! Printer mg7140. Replaced the print head, replaced the cartridges, cleaned it, cleaned the GRM. The problem is as follows
Hi. I have a PIXMA TR8660a printer for about a year. Not much use. Recently, the Cyan ink stopped working: not blue colour coming on the paper. Ink levels show as normal and the 2 new Cyan cartridges I have put in, show that they are expended!I tried...
Hello, I was thinking of purchasing the Canon G620 photo printer and wanted to make sure it would be compatable with Mac OS 14 Sonoma.Can anybody verify they have used it with the latest Mac OS ?
My 6-month-old TS9120 worked flawlwssly until last night. Now the printer jams every time trying to print the backside in autoduplex. Single side printing and the front side of duplex printing still work fine every time. But when I try tp print in...
Replaced black ink cartridge and get error code 1684. When I put the new cartridge in, it beeped so I put it in correctly. I have tried powering down and restarting, but no joy. I am running Win 11.
Support code 5200 suddenly appeared while i was doing black and white printing. Stopped and restarted the printer, But code is again and am unable to print.checked my ink levels, its more then half tank. I cleaned, deep cleaned and even ink flushed t...
Hello.A Canon web page states:"The borderless printing feature allows printing without any border by enlarging the data so that it extends slightly beyond the edge of the paper."Is it not possible to print all data without loss of information?That is...
I have MG7100. It will print from my phone or PC but won’t make copies.I have rebooted it and no luck.Help please.Thank you
I've done all the cleanings, and put new ink cartridges in, but these lines keep happening. Is there a way to remove the cartridge holder to clean, or is it something else? TIA
Subject | Author | Posted |
05-20-2024 08:56 PM | ||
05-20-2024 05:29 PM | ||
05-20-2024 03:25 PM | ||
05-20-2024 01:56 PM | ||
05-20-2024 05:37 AM |
