MX860 driver version: no grayscale
I installed a new version of the driver for this printer; prints just fine but only printing in black / gray is not an option Anywhere I can find... any suggestions?
Our Pixma MG7720 has gone downhill. A few months ago we started to have to have all prints set to high quality or they'd come out looking bad. Now everything we print is just horizontal black lines. Even the nozzle check is a mess. We've ran ever...
I'm having the hardest time. On My Image Garden there's no film postive/negative selections. Just photo, document and magazine. I'm not even sure if this is an actual magazine. So confusing.
The scanner on my MX892 is only scanning a small strip of the document that is on the glass. This is also happening in the document feeder.
Hi - My Canon G3200 has performed fantastically since I got it a couple of years ago. I have used non-Canon ink since the provided bottles ran out, and that has not been a problem. Today the printer suddenly decided that ink levels are low, although ...
Hello,I'm setting up a new TS8320 multifunction product. The connection is through wifi. The printer appears to work fine; and I can scan images using the Canon IJ Scan Utility. But this program is clunky. I want to use my photo editing program to sc...
My Canon G5020 is printing colors inaccurately. See included images. The first one is the printout; the second is the source. The heads are not clogged. I've cleaned them, deep cleaned them, and did an ink purge. The print test comes out perfectly… j...
The error and power light flash 26 times. The inks cartridged don't return to center and all of the ink cartridge liights are off. I've reset the cartridges and printhead to no avail. The printer worked flawlessly just one day ago. The printer is two...
Just a few days ago, I printed some labels that were on a 4 x 6 sheet. Everything turned out fine. Today I want to do the same thing, only with a different label. I used Avery's template that matches my labels. When I tell the printer that I am ...
I keep checks in the rear paper feed in my TS8320 and have followed directions to set the Main Cassette as default feed. This fails often enough that it is infuriating. Usually if working directly on software resident to a computer I can check the fe...
Canon TS9020 Scanner Printer Combo.It was working fine until today.I turned it on and a message was stuck on the display screen:"Support Error code 5011Printer error has occured.Follow the steps below.1. Cancel printing, then turn the decide off.2. T...
The message is pretty self explainatory but how to solve it isn't. Says need to replace ink absorber pads but I can not find any explaination on how to replace the pads. Worse yet I can find no listing for Canon approved service centers AND the Servi...
I tried both Cleaning and Deep Cleaning. Every ink cartridge is brand new. But every print job I send to the printer, black/white or color, comes out nearly blank. Is this a driver or hardware issue? Odd thing is, when I scan/copy, it prints okay. ...
The other day, while printing two-sided, I had a paper jam. Removed the paper intact (no bits left behind), but ever since, my printer won't print the full page - the bottom one inch of text/image is missing. This happens in all programs - Word, Ad...
Pixma MG2520 printer. Last night the jam light started flashing, but there is no jam. I checked online for solutions. Tried them all. Nothing worked. There is definitely nothing stuck in the computer.
Subject | Author | Posted |
04-25-2024 07:02 AM | ||
04-25-2024 05:02 AM | ||
04-24-2024 11:04 PM | ||
04-24-2024 10:47 PM | ||
04-24-2024 10:59 AM |
