Canon_MP495_series
When I want to print an email,I get the message"Error While Printing" What is causing this problem?
help!!!! i need to scan my passsport and and put it onto my computer
I'm hoping someone can help me! I have a Pixma MX870 printer. It's about 10 years old. It works through Bluetooth on my laptop. I recently bought an iMAC desktop but I can't install the printer. When I go to system preferences and search for the...
So, I thought I did all the research I needed to do to find the printer for me. I was wrong. Firstly, this printer (G7020) does not perform duplex scanning (aka double-sided scanning, dual scanning, scanning both sides). Any post anywhere that says...
I just setup my TR7020 printer/scanner and attempted my first scan. It is showing a vertical white line on anythingI scan. I've tried cleaning the surface, but that has no effect. Anyone seen this kind of problem?
My Pixma MX410 won't turn on, flashes for message 'printer error has occurred, 5B00.' It previously indicated a full ink absorber, bypassed by pressing 'OK.' Cannot access the ink absorber to clean it. Any fixes or must I take printer to repair?+
printer recognizes wifi, but pc is not recognizing printer when i try to install new printer
My MG3522 will scan preview but will not scan print. It causes the computer to lock up and I have to reboot to clear. I have reloaded the printer software to no avail.
I cannot get my printer to print from the rear tray.
Scan Utility complains that it can't find the scanner. Printer is on. Printer is connected (USB only). Printer can print. Document is loaded. ScanGear reports this error code: 5,156,69. Any ideas?OS is Windows 7 Pro 64-bit. Downloaded the latest driv...
my Canon mx920 All in one printer. Wireless setup. Does not print. Defaults tp FAX rather than printing. I have deleted and reinstalled the printer several times. I wonder if it's because the Descrfiption says it's a FAX. Does not include the wor...
Hi, My Canon Pixma MG5220 Printer for my mac is printing fine but not scanning. I recently updated the OS to Catalina v.10.15.6 which may be the problem. Support would be much apprectiated.
Dear Support, I have a Canon PIXMA Serial Number KJGE[xxxxx]. I am unable to identify the model and unable to use the printer as it is stated the driver is missing. Please help. Thank you. [Numerical portion of serial number hidden for privacy.]
Hi, I have a Canon G3010 printer. When I set it up, there was no issue, but as soon as I start printing, there is the error that my PC cannot connect to the printer though when I open the web settings page, I can access it and change any setting with...
Subject | Author | Posted |
04-30-2024 03:44 PM | ||
04-30-2024 08:57 AM | ||
04-30-2024 12:14 AM | ||
04-28-2024 12:33 PM | ||
04-27-2024 04:40 PM |
