MX410 printer connection with windows 10 S
Is there an app available that will allow me to download printer drivers with operating system windows 10S?
After cleaning print head via printer.. The printing was okay. Deep cleaned via printer one more time. The next day I tried to print again and received code 1410. Replaced with new Y and PGBK cartridges. Changed nothing. Still shows code 1410.A...
I'm on Big Sur 11.5, but since I got a new iMac and had Big Sur, not all function of my printer have worked correctly. First I downloaded a new printer driver and now I can print. But it still won't scan. I downloaded the latest scanner driver. Still...
So I just got this printer and I love the quality and all however the printer stops midway through print job. I'm printing double sided curriculum pdfs. Some jobs are 2 or 300 pages. It just stops with no error messages or anything. Anyone else have ...
I have cleaned the rollers 5 times. I put in fresh paper, I made sure the paper guides are in the right place. I made sure the computer settings are correct (paper size, lower cassette, plain paper...) and it still says no paper in the lower cassette...
I have a PIXMA MX 300 printer, I'm using Windows 7 OS. I have downloaded the latest driver. The paper will not feed; there is no paper stuck in the machine and turning it off and on won't clear it. The printer does not even pull the paper in. As soon...
Hello! I have Canon printer PIXMA 492, and it is showing Code 5100, and so far none of the suggested fixes I have found in the manual or online have resolved it. I have tried turning it off and on; turning it off and waiting 30 seconds and turning i...
When I scan an A4 size document the left side of the sheet looks completely black as in the attached image. Previously the scanner worked correctly, but now this always happens. I have tried on two different laptops and reinstalling the drivers, but ...
My printer is asking for a PIN number for a Blue Tooth Connection - to the best of my knowledge it has never had one. What can I do?
When I try to set up my system to send faxes from my Pixma G7020 using Windows 11 It keeps asking me to eitherconnect to a Fax modem or "connect to a Fax server on my network". If I select "Fax modem" 0f course it tells me I don't have one connecte...
Hello from Ohio. I am attempting to create and print sentiments for the inside of my card. I have the full Canon program and I am unable to figure out how to type in a sentiment only (no pics) and print it... I only find 'cards' being created with ...
Just joined. MX worked perfectly - then suddenly it will not make a Black copy - just a blank page.. I have tested (both wireless and LAN) with the nozzle program and it prints everything EXCEPT the Black section on top (PGBX). I have cleaned many ...
Hello, My Pixma MG 5650 connects fine to my computer for pritinting but when I try to scan, my computer can't be found by it.I have installed the Canon IJScanner14f on my Mac OS10.15.7 Catalina then when it didn't work I completely deleted it with th...
Canon MG5420 wireless printer one year old. Has worked perfectly until today. Will print a page of text from MS Word, only if the the “Fast” setting (less ink) is used. When attempting to print a page of text on “Standard” setting, prints the top one...
I have an issue that I see referenced here and there on the Community Forums and in my Google searches. Unfortunately, I haven't been able to determine a Canon supported solution or a workaround. I use Google Cloud Print Services to print from my C...
Subject | Author | Posted |
04-23-2024 09:51 PM | ||
04-23-2024 02:15 PM | ||
04-23-2024 08:22 AM | ||
04-22-2024 09:31 PM | ||
04-22-2024 07:23 PM |
