Desktop Inkjet Printers
Scan an image from the platen TR4520, G6020
Trying to scan an image into a .jpeg or .png file. I hear the printer making sounds and it shows... SCANNING SCAN SETTINGS  It makes several passes as if it is scanning (10 seconds+/-), then it gives this error message ERROR The 2,157,50 talks about ...
scan image from platen...scanning.jpg scan image from platen IJ settings.jpg scan image from scanner bed cannot communicate 2.157,50.jpg
Pixma MP990 Won't Scan
I haven't changed a thing on my MacBook Air and tried to scan today and I get the following pop up: You do not have permission to open the application "CanonIJScanner1". Contact your computer or network administrator for assistance This is my persona...
lbrigman by Apprentice
  • 608 Views
Code: 5, 157, 69
My MG 3620 stopped working to scan though the IJ Scan Utility. I made sure everything was up-to-date, I made sure drivers were up-to-date, I uninstalled and reinstalled, I disabled and reenabled, and I am even using a wired connection (USB). I downlo...
windows 10 stopped detecting my printer
Windows 10 stopped detecting my TS8120 inkjet. It was fine Monday; the problem started yesterday. The printer is listed in hardware as the default printer. I restarted my laptop and shut of the printer off and on. No deal. It's on WiFi.
Vivian07 by Apprentice
  • 520 Views
  • 2 replies
Cannot connect G7020 scanner to IMAC
Cannot connect G7020 scanner to IMACMonterey operating systemPrinter is connected via wifi (printer works great)When I select IJ scan utility items I get the following Cannot communicate with scanner. Possible reasons:- Scanner is turned off.- (If us...
risi6701 by Apprentice
  • 487 Views
  • 0 replies
Pixma TS3320 error messages
Any attempt to use the "Canon IJ Printer Assistant Tool" for my TS3320 fails. For example, the attached clip shows an attempt to use that tool to suppress "mismatched paper settings detection" and the resulting error message #0xc000012f.Is there a wo...
Setting up a PIXMA TS3522
Which of the following is true: I can set up this printer to print wirelessly from my desktop computer AND my smartphone.  That is, I can print something from my computer, and then print something from my smartphone, without having to do anything spe...
TR8520 printer.
Yellow ink cartridge was getting low so I replaced it with a new one. The estimated ink levels that show the ink remaining is still showing the previous cartridge's amount not the new amount in the new cartridge. I have taken the cartridge out, check...
MG7520 not working
My pixma MG7520 only worked 1 year before it started showing "Suppport code" B203.  Someone on this forum mentioned having to update your printer as your computer updates (ex. I have a mac so when auto iso systems update, the printer needs one too.  ...
Error Msg C000
Tried to print. Get Printer Error. Turn off/on. Problem persists see manual. I download manual, search c000 to no avail. Call 800 support. Can't talk to anyone until I register printer. to register I need ser#. Can't find. eneterd every number on the...
waju by Apprentice
  • 756 Views
  • 3 replies
