Resolved! G5020 Prinhead
Does any one know the Part Number of the Canon Pixma G5020 Printheads (Color & Black). Please provide a source if known. Thanks!
I have a Canon Pixma MX492 with the same problem. I am able to print, but scanning has suddenly stopped working. I am using MAC OS Monterrey 12.1. I don't recall updating my OS recently, but it's possible that I did a small update.I have tried uninst...
I have a PIXMA TR8520 printer. All of a sudden, lines began appearing on the printed paper. Holding a sheet of 8 1/2 x 11" paper vertically, the lines run from side to side. They seem to appear only on photographs - not on text or other graphics. Wh...
I have a Pixma mx9222 printer. It has started showing the evil B200 error. I have changed cartridges, changed the printhead, done a reset. It continues to persist.I tried the trick by Debillkeef involving opening and closing the door, but while that ...
Brand new machine! Never had a chance to use it yet. Just testing it out and I can't get it to feed the paper in straight no matter what I try. I have yet to complete a decent copy of anything because the paper jams up every single time I try to make...
I have a new MacOS Monterey and my MP495 printer is offline. I have checked all plugs and the printer is working but I don't know how to get it online.
I tried to print on an envelope and apparently I put it in the wrong way. The envelope is stuck and I don't know how to get it out. I also tried to call product support, and for some reason they cannot recognize either of the two telephone numbers I ...
Just got my new printer a couple weeks ago. I have yet to be able to print from the rear feed. I am trying to print from the rear feed and I keep getting a code 1000 which is either paper is loaded wrong and/or there is no paper loaded.1. Paper is th...
Support Code 2804 MDF failure to scan. 'doc size not suitable for duplex scanning'. Win 7, Pixma MX922 Tech support tried valiantly to figure this out but could not, so I'll share my solution. I suddenly kept getting Support Code 2804 failure on M...
Just opened and set up my tr8620. Very first photo comes out very pink. How do I fix this? Thanks.
Can anyone tell me how to retract the paper tray on this printer? On unboxing, it was retracted making the front completely flush. It pulled out ok but doesn’t seem to want to retract. Any advice?
My printer ink is new, off brand ink ordered from Amazon a few months ago. I installed the ink, but when I print anything in black or color, nearly half of the page is not printed or the printer spits out a blank sheet with zero ink on the paper. Thi...
I have a PIXMA TS9020 printer. I have this error during scanning ''Printer is in use or an error has occurred. Check status. Scanner driver will be closed. Code: 2, 140, 3.
I replaced the carts in my printer in early October, according to my amazon order history. Since then, I've printed about 2 dozen pages of text and nothing else. No photos, no pdfs or sheets with large filled areas. Just text. Today, my printer is co...
I have a Canon MX922 every now and then I keep getting an error tells me to shut it off unplug it then plug it back in and turn it back on but the air is still there I'll wait a few days and then the air disappears Don't know why
Subject | Author | Posted |
05-17-2024 02:39 AM | ||
05-16-2024 12:18 PM | ||
05-15-2024 09:04 PM | ||
05-15-2024 08:14 PM | ||
05-15-2024 06:38 PM |
