Issues with my printer
i cant get my printer to show up on my computer i have it connected to the usb and all it shows is set up the printer and i try and it asking for a model and i put in the model cannon MG2522
Frustrated with printer, especially since it worked correctly when I first got it. Now it won't feed from back when set to do so. Also it always pulls one sheet of plain paper through before it prints on a second sheet. Another issue; I bought thi...
I bought a new Dell i5400 All in one computer with Windows 11 installed. When I plugged in my Canon MG7720 printer it would not print. I tried downloading drivers from the Canon Support but that did not solve the issue.
After clearing a paper jam, which involved briefly removing (and replacing) power cord, printer will not operate. Troubleshooting function detected no solvable problems. Computer does not seem to be finding the printer. Touch screen does not illumina...
I'm using a Canon PIXMA MG2450. On my old Epson scanner I could scan images, save them as jpegs I think it was, and edit them using photoshop etc. But my new Canon printer/scanner comes with a programme called My Image Garden. I do NOT want to use an...
My PIXMA MX472 is showing code 5100. Paper was jam in the printer. I was able to get the paper out. I then turn it off and back on and it still shows code 5100. I need help to fix my printer for my job.
HELPPPP! i need to connect de printer in my laptop with windows 11, which one is the driver? Everything starts fine, I follow the instructions and plug the cable when it should be and it doesn't work, I uninstall the driver, restarted, I start again ...
My serial number is KJWE[remainder of serial number removed for privacy]. Can someone please help me?!
Tried removing printer head procedure to reset following Cannon instructions but it failed to reset head. Still getting support code 1403 and locked up. Printer worked flawlessly one day. Next use get 1403. Is their something else to unlock support ...
I tried every one of these suggestions with no positive results until the last. I reinstalled a new driver from Canon and Bingo...I am back in business. Now if I can figure out why some of my pictures are printing so muddy.
I have 2 of these printers...one at school and one at home, and they both are causing me headaches. I just posted a message about paper jamming and now I have this at my home printer. I can print in color but the black is streaky or will print off ...
When the printer receives the print command, it does not grab any paper but goes through a printing cycle, presumably wasting ink onto the roller. Then it gives an error code about a paper jam and paper not exiting. There is no paper jam. I've put fe...
MG5350S having problems printing Cyan colour, after many cleaning cycles produced no result - removed and manually cleaned print head. After cleaning and drying head nozzle check produced PGBK ok No Cyan, Magenta passable, No Yellow, No BK, cleaning ...
Hello, have had this printer since 10-2021, and all of the sudden the white & amber lights are alternating flashing & error code 6A81 comes up. Tried a few times to check for any paper jams (none), and tried unplugging & plugging back in (no luck, s...
Don't know how this happened, printer was working (and scanning) well before I moved. Now won't scan. Appear to be 2 hinges, one of them is completely detached, the other has a flat cable beside it. I cannot completely insert the 1" x 1" plastic pin...
Subject | Author | Posted |
04-22-2024 09:31 PM | ||
04-22-2024 07:24 PM | ||
04-22-2024 07:23 PM | ||
04-22-2024 04:35 PM | ||
04-22-2024 08:49 AM |
