tr4720 printer photo comes out blank
I put the paper in the right way, and presume I have ink installed correctly, but I press enter and it acts as though its printing and the photo comes out blank.
My PIXMA MX922 is leaving a streak along the right side of each page when feeding from the top automatic feeder. I have cleaned the roller on the top feeder and did the roller cleaning from the maintenance menu but I still get the streak on the righ...
Hi Team,I kept on getting the following error msg while trying to print/scan on mg2520 on a macbook pro with Big Sur 11.2Cannot communicate with scanner for these reasons:- Scanner is turned off.- (If using Wired LAN connection) It is disconnected fr...
Recently, my Canon PIXMA MX479 appears to be washed out when scanning pictures, It looks whiter than usual on the preview scan, and I don't know what's the issue It never happened before. I would appreciate if someone would help me out here. Thanks.
I have replaced the ink cartriges and i still get the low ink/out of ink warning. the black ink show low and the color in says it is out. what do i do to reset those two warning lights?
When scanning from my MX922 I receive an error. I can find nothing addressing this since 2016 and the advice was to call customer support at the time. Please help & if I need to call in, let me know.
I, too, am having this same issue; I am in Mac OS operating system, connected to the printer via Wifi. I load the vinyl paper in the rear feed, close the feed slot, and select "Letter" and "Matte." When I click print in Design Space, it only wants t...
this just started happening a couple weeks ago.My MG5520 won't print black text using Media Type Plain Paper, but works fine w/ Media Type Photo Paper. My understanding is that by choosing Photo Paper it actually creates black ink from the color car...
My PIXMA MG3520 will not print when I hit "print" I get an error message "another computer is using this printer"Then, sometimes, when I turn the computer off and then back on, it will print the last document that I wanted printed.
Just purchased a Canon pixma G1520 printer, it only connects with a USB cable but I can not get it to communicate with my desktop computer.I have also searched for G1520 specific installation files to download but, each time, I am guided to G1020 dow...
I have a brand new G7020 and when I print a color test pattern all of them, including black, are washed out. I don't see a way to attach files but I can give you links to the test pattern and a scan of my printout. The difference is dramatic. This...
My MP470 will scan but will not print from any computer. Could the USB cord be bad ? I got it used so it’s a possibility that it’s old. The computer will say that it has completed the print also ... has anyone else experienced this?
the copy button is illuminated. I am trying to make a copy thru the top feeder, and also tried lifting top and placing face down. I get a message that says document cannot be scanned from ADF when setting auto intensity or fit to page. Have never had...
Trouble light code 1485 Pull color cartridge printer works sometimes. Brand new used for first time. Wiped contacts negative results. Ordered new color cartridge.
I am trying to scan using the document feeder. I press the scan button, then the start button. The printer screen reads "please wait a while". Nothing happens, it never feeds or scans.
Subject | Author | Posted |
04-30-2024 12:14 AM | ||
04-29-2024 07:28 PM | ||
04-28-2024 12:33 PM | ||
04-27-2024 04:40 PM | ||
04-25-2024 07:00 PM |
