PIXMA MG6220 can't print from MacBook on Big Sur 11.5.2
Help - I cannot print anymore from my iPhone11 nor my new MacBook on BigSur 11.5.2. It seems that it is not longer compatible with a new driver or anything?!?!
My Canon printer is giving me a "ink absorber pads are almost full". Does anyone know if they can be replaced and how to do it? I can't find information on this error code anywhere.
I've got an old Canon i960 printer running in Win10. It still works well, still makes beautiful prints and I refuse to consign it to the recycle bin until I see smoke rolling out of it.Bur recently I've installed Easy PhotoPrint EX because it made it...
Hello, I have noticed the printer has been printing faded pages for only certain documents, especially those with confidential information. I tried to print the same without confidential info and it works just fine. How do I fix this?
Had a canon MX922 and was using the IJ Scanner Selector EX software to scan from control panel. Replaced printer/scanner with TR4720 so do I need to download a different IJ Scanner selector EX in order to be able to select the TR 4720? When I pull up...
I have a Canon TR4520 and when i send to print something to print.it receive the paper but then it will spit it back out then i guess it will try to take it back in but it will be not straight to take it back end. i tried to clean the rollers and res...
Hello, recently our printer ran out of black ink and we replaced the cartridge. Now no black ink will come out at all. I have tried several different new cartridges. Same result. The color cartridge is low, but still works. If I do a nozzle check, al...
My CANON MG5720 OCR says it can't connect. But my computer connect to the printer to scan and do other jobs, just not OCR. I have both USB cable and WiFi connection to the printer and all works well except OCR.Here is the error message I get. Is...
Hi new with using this newest model canon printer scanner copier and fax; use the fax infrequently only just noted when I click on faxing from operations panel I see FAX MODE START/OFFHOOK, never noticed before just started inputting number after cli...
prints black and white ok..won't print color
I have a PIXMA TR 8520 and I'm scanning a photo into my laptop operating on Windows 10. For some reason it will now only scan as a PDF. It used to scan as a jpg which is what i need. Any suggestions?Thank you!
I bought a new printer in February and ran out of black ink last week. The required ink cartridge is PG275. There are none to be had - not in retail stores, not at Canon on line, not at on-line stores like Amazon. So I have a printer that cannot ...
Suddenly today nothing prints on my MG5300. The print job is set to the printer and it goes through all the motions but the page comes out blank. The cartriges are not empty. I also tried to copy a page and the same thing happened; it scanned the pag...
I have a pixma mx360 which isn’t wireless. what adaptors do i need to make it wireless? please be specific on accessory needed. please please help!
Subject | Author | Posted |
03-29-2024 12:03 AM | ||
03-28-2024 05:14 PM | ||
03-28-2024 04:51 PM | ||
03-28-2024 04:05 PM | ||
03-28-2024 01:24 PM |
