MX410 Printer
My Dell Inspiron 15 computer using Microsoft Edge will download the MX410 Printer driver but shows its as being unable when I try to print.. printer was fine working with my old MAC computer .. how to fix problemÉÉ
I've just upgraded to MacOS Monterey 12.4 and my MG5750 scanner no longer works. The printer works fine. Any suggestions? Thanks
My Canon MX490 AIO printer started to power cycle with only the Canon logo showing on the printer display. The printer will move the ink cartridges then the rollers will move and click then shut off then turn back on and start the same cycle again. T...
I don't use my printer every day, so I keep it off unless I need it.Every single time I start my computer, I get a pop-up warning that I haven't turned the printer on. I've dug through every printer menu I can find, including the startup programs (ap...
Here is the fix everyone!
I did a fix by turning off router then turned on printer and changed the dns server manually from all zeros to 001 on the end. ( in printer’s setup tools). Then turned off printer and turned on router, waited till all booted up. Turned printer back ...
My cannon started printing poorly to the point where you cannot even read the text. I have changed all ink cartridges, cleaned the head, deep cleaned the head, did an aligner adjustment, cleaned the rollers, and ran the troubleshooter. I am at a comp...
My father has used this printer for the last few years, it's a great printer, although a bit slow in general. He notified me of it not working. I checked, and searched it up, and saw the numerous amounts of posts on this issue. This is a house printe...
So it doesn't seem like there has been any input from Canon about this problem they caused with our wireless printers stuck in a power cycle loop. Seems there are a couple of work-arounds, but no fixes. I ended up hooking up mine to the computer wi...
I've been printing color labels with an Epson ET-2550 for many years. The label I use most often is on an 8.5" x 11" page but the label itself is 8.1875" wide by 10". This leaves margin of .1625" on each side of the paper. My Epsons had no problem pr...
Someone on here had a work around for a MB2320, so I thought I would try it for my Pixma MX490......and it worked!1. Unplug the printer2. Unplug the modem ethernet from the router (You could also turn off router)3. Plug in the printer - it will turn ...
My MX492 started going on and off constantly without any involvement from me. I tried to do the firmware patch but could not get the printer to stop cycling. With no success here I am?
Canon Pixma MX490 Keeps on and off cycling (rebooting?)I have used my scanner/printer (MX490) so far without any problems. Thanks!But last night I had a problem with the power on and off continually.If I turn off the Wifi, it works with power on and ...
Brand new TR4720. Worked fine. Showed in Control Panel/Devices. Then I messed up a setting and removed the printer and reinstalled. Now it does not show in Control Panel/Devices. It works fine. It shows in Device Manager. It shows in System Settings/...
Subject | Author | Posted |
04-28-2024 12:33 PM | ||
04-27-2024 04:40 PM | ||
04-25-2024 07:00 PM | ||
04-25-2024 03:03 PM | ||
04-25-2024 05:02 AM |
