MP280 no power alarm light on
MP280 no power, alarm light on, computer offline. please advise
HOW TO GET MY PIXMA G7020 BACK ONLINE
I just changed the black ink cartrage and it will not switch to black ink. Ive selected black only. Ive even set it in page setup to greyscale and it still will not switch to black ink. I hit the button on the printer itself and Ive tired to turn ...
Are there softwares available for my MP495 to work with a MacBook Pro computer?
SOLUTION: After a 1:57 hold time with Canon customer service.... I have the solution! (and that was 2 hours, not 2 minutes) If this is happening to you it is very easily fixed. [Removed per forum guidelines] Although I wish I could make up for my 2 +...
OS Monterey, Pixma MG7520, iPhone 12When trying to print from iPhone the paper size changes from 'Letter' to '4 x 6 inches' after selecting the MG 7520 on network.
I've been having this issue for months where my heavy 5x7 matte prints will consistently be shifted downward around a centemeter cutting off the bottom of the image and leaving a white band across the top of the print. It doesn't have this issue with...
Hi! What's the heaviest GSM paper I can safely use in my G2260 ink tank printer? Thanks
As the title asks the question…what happened that caused all of the printers with internet access to behave the way that they did on the 31st?I think in the spirit of transparency that we should be given an answer as to what caused the problem. Also,...
It's three weeks old. It printed 20 pages, and then decided it doesn't know what ink is anymore. It forever links that there's no ink in the printer, even though there are two brand new cartridges right in there put in after the starter cartridges ra...
Hey guys,I've had this printer for quite a long time. I run my small art business off of it. I noticed some black streaks so I decided to perform maintenance, I first tried to run "clean printer heads" and kept getting error 6C10.Thought that was wei...
How do I resolve if there is sufficient ink in the containers?Do I have to replace the ink cartridges?If so, how often is replacement required?And, finally, how do you do it?Thank you.
I replaced an ink cartridge and no matter what I do I get the support code 1411 message. I’ve tried reinserting it and a hard reboot, nothing seems to work. Any suggestions???
Hi all! I hope someone can help me with this. My printer's never had trouble before, but last night I was trying to print a letter from my PC (letter created in OpenOffice) and the printer will only print the first three lines. Actually, it's weird -...
I bought it secondhand, the language on the LCD is mandarin. I tried what was recommended on Canon's troubleshooting (press menu 3 times, press >+ 2 times etc) but that did not lead me to a menu to change the language. Please help.
Subject | Author | Posted |
04-27-2024 04:40 PM | ||
04-25-2024 07:00 PM | ||
04-25-2024 03:03 PM | ||
04-25-2024 05:02 AM | ||
04-24-2024 10:47 PM |
