PIXMA MX922 Shuts Off and Won't Come Back On
I went to copy and the printer shut completely off. I unpluged for over a half hour and still will not come back on. Any suggestions?
I have never in my 16 years of using Canon printers had such a difficult time installing one. I ended up using my old usb cord from my iP7720 to connect via a usb hub, it took 4 hours and finally I ended up installing it manually. However, I was al...
I recently got a new laptop and am setting up my Canon MX922 wirelessly with it and I got everything installed using the cd and both the print and copy functions work fine (haven't tried fax) but I can't get the scan to work! It worked perfectly fine...
Im not sure if anyone here can help with this but im trying to print stickers on transparent paper but the ink comes out really transparent, is there a way I can make the ink more opaque? A solution I saw was having a white base so the ink wouldnt sh...
I was in the middle of printing a batch of 4x6 photos and all of a sudden the printer made a very odd noise and the picture that came out had runny ink that got everywhere. I tried restarting my phone, computer, and printer, no dice. 5 test photos ha...
How can I print only using the PGBK cartridge on my MacBook running Monterey? I rarely print in color, but both my BK cartridge and all of the color cartridges are running out, and the PGBK is full. It also prints pretty slowly for printing only bla...
Slot for mx532 messy with 240 xl black ink.
After replacing the color cartridge the USB failed. Initially the yellow Color Ink LCD was flashing and the green power LCD were flashing. I had to pull power to the printer to get the tray to go to the middle. I replaced the color cartridge and t...
Good day,I own a TS6220 printer. I just moved my printer from a table to another one, and now when I turn the printer on, the display only shows ''Canon'' and it stops there. When I moved the printer, it was already off, I unplugged it, moved it and ...
Can anyone help me out?I have a Canon PIXMA ip8720When I print any type of larger area with black I seem to get these roller lines, or at least that's what it looks like. It's only with black. I'll attach a photo. As you can see, the red is fine, no...
I cleaned my own ink absorber pads myself (not easy since they don't build the ink pads to be very accesible) a few months ago and the printer has been working fine but now it's giving me the EB00 error. I've tried every solution including unplugging...
I have had a reliable experience with my G4200 printer until recently, when it started to skip entire lines of text when printing.I have tried several approaches to fix this issue:nozzle check (black is missing the middle portion)cleaning and deep cl...
Am I able to set it up to print 5 1/2” x 8 1/2”
I have an iMac with it's latest OS X 10.11.6 and an MX922 printer. It was working great, but then I tried to also connect my new MacBook Pro Big mistake. Printer not working well since. I deleted the printer in ystem Preferences, dowloaded all new dr...
Subject | Author | Posted |
04-25-2024 07:02 AM | ||
04-25-2024 05:02 AM | ||
04-24-2024 11:04 PM | ||
04-24-2024 10:47 PM | ||
04-24-2024 10:59 AM |
