hi i have a canon mp 495 . i keep getting a paper jam error and there is no paper jam. i have tried the reset button ,i have lifted the scanner to check for jammed paper ,i have unplugged the printer. the supportt code is 1300 and the error codes are...
Just set up a Pixma G6020. Working great, set up was fine and I'm generally happy with it. But, photo printing has been poor. The basic problem is that photos come out underexposed, slightly desaturated, and with a warmer yellow tone than the file...
MG5750 will not start/power up after clearing a paper jam which entailed accessing the front and rear (via the sliding access door) to get at all the scrunched up paper. Wonder if I have done something terminal to it in the process? I left the machin...
Hello, I have a Canon MP287.Both the color and black cartridges, some of it's nozzles are closed (has lines in the test print). I've tried deep cleaning about 5 to 7 times but it's still the same. I did buy a cleaning solution (it looks like Windex w...
I have a Canon G3501 that has been working without issue for a year. In the last week, however, it has started printing with distorted colors. I did a nozzle check and magenta seemed to be clogged. Cleaning and deep cleaning didn't help, so I removed...
Are the multipacks of C\M\Y\Black 271xl and 270xl ink still available. Tried searching by printer model and ink number but could not find. Also looked at other sources but can't find there either. Hopefully these ink cartridges are not being disco...
The OS in my laptop always get update when connect to Wireless Connectivity but after that i can't connect again to canon mg2522 printer when want to print a document what must i do?
I've recently gotten a Mac, after using a PC. I'm trying to fax from the Mac through a PIXMA MX492 multifunction printer (which worked just fine on the PC). The instructions on the Mac support site say Open your PDF document, select file -> print, ...
Hi everyone! I bought a Canon G6020 a few months ago and I cannot for the life of me figure how to align it properly. I print my product labels from home and for the non-borderless labels, it's off by the tiniest bit EVERY TIME. For my borderless lab...
All colors have worked beautifully since installing. Suddenly, yellow has stopped working. Tank is half full. Clean and Deep Clean has been done multiple times. No change. Removed the color print head and can see a yellow liguid bubble at the no...
Good afternoon, previously I had a desktop and my printer was connected. Now I have a laptop and not connected. The printer is on, but the yellow light is on and I'm not able to print.
how do I adjust the printer settings for an 2 per page 5 x 8 label , present setting won't print properly on the label area
Subject | Author | Posted |
04-23-2024 02:15 PM | ||
04-23-2024 08:22 AM | ||
04-22-2024 09:31 PM | ||
04-22-2024 07:23 PM | ||
04-22-2024 04:35 PM |
