PIXMA MX492 How to Enter Numbers via Keypad for Network Password
connect Mac ventura 13.2 to pixma MX492Printer requests password for router. Printer phone style keyboard doesn't offer numbers.I'll try using wire.
I downloaded a update to my MG 5620 today. Now I am receiving Code: 1689. In past prior to todays update, I could bypass that code easily with just touching the Black print indicator. That did not change screen or print. I checked my ink cartridg...
how to print the 2nd page on canon printer Pixma G 620 manually what to do after the 1st page done
Has anyone used the g6020 for edible images? Where do you get the empty cartridges so you can fill with edible ink? This was listed as one of the top edible image printers and it’s of no use to me right now. Please help!
I have a TS5320 printer that I bought in 2020. I don't use it that often, but I noticed when I first purchased it, it seems to run through ink incredibly quickly. I called customer support and they said it didn't sound normal so they offered to send ...
I have been trying to find a way to reach support with my issue since I bought my printer in 2019. I don't know if anyone from Canon reads this, but I thought I'd give it a shot. I keep checking for firmware updates and noticed they recently updated...
I'm following on screen set up instructions to the point of aligning print heads, but the A4 sheet I've inserted won't print. The document shows in the print queue but that's it - nothing happens. So I can't complete the set up process. I should say ...
I own a canon pixma mx922 printer. The problem is if I'm on my computer and want to make a copy,it won't copy. I called best buy tech support and they tried to install the drivers. But that didn't work.If I put a document on the glass, and hit pr...
Hello,I have recently bought Canon PIXMA TS6420a printer/scanner, however when trying to install drivers and the software I have found out that it does not support Windows 8 (the operating system I am currently running).The printer is working fine wh...
Hello! Can the pixma g3202 series be converted into sublimation
Canon TS6240
Any suggestions for installing the recommended downloaded driver for this printer? I can download from Cannon website but it fails to open. I've tried numerous times but no avail. I've also tried via USB but the software does not appear in the softwa...
I have an error message on my printer which reads:5020Release the scanner lock switch and turn off power then back on again.I need a detailed instruction to correct my printer problem.Edgar[Email address removed per forum guidelines.]
How do I fix this error: "Preview Print Error. Not enough memory to print" . Thanks. I have a Canon PIXMA TS9500.
Hi! Do anyone have any idea if I can still use my scanner, my printer is Canon G2020, I have a support code 1726, which I know I need to replace the maintenance cartridge, my concern is, if I can continue using my scanner while I am not able to purch...
Subject | Author | Posted |
05-17-2024 10:43 AM | ||
05-16-2024 12:18 PM | ||
05-15-2024 09:04 PM | ||
05-15-2024 08:14 PM | ||
05-15-2024 06:38 PM |
