PIXMA MG2522 Chromebook Connection
Try get my canon pixma mg 2522 to connect to my LENOVO 300e chromebook 2nd generation laptop what need to do to make it print
MX922 worked on Win 7, but when I upgraded to Win 10, new installation doesn't recognize the printer.
When I print the photo on other paper sizes (8x11 & 5x7) - it all prints perfectly centered/aligned. For whatever reason, only the 6x4 is printing out not centered (shifted left). I thought maybe it was the thickness of the paper, so I cut my other p...
The colors I print are now way off and the Print directly is different. I have always printed without having to change any color options and now I can't get it to work correctly, even with playing with all the color sync vs manual color. I usually ...
I'm having trouble installing my printer to a new computer with window 11. It looks like their no driver for window 11
After a paper jam while doing duplex printing, my MX532 printer is printing with a severe shadow and prone to jamming with an error code 5100. I cleaned the encoder film and now does not jam as often. When I try to fix the alignment, it jams (with ...
Do you take the empty 271 series cartridges back for refilling?Thanks,John
My canon PIXMA G3010 printer is having problems turning off, disabling the WiFi connection, or initiating Direct connection when it is initially connected to the WiFi. I have found that this issue is related to the printer attempting perhaps to acces...
It was working recently! I only print a few pages/week. Now it does not print black text. I have Windows 11, fully updated. I've rebooted the PC. I've followed online troubleshooting pages mentioning this problem, tho not for this specific p...
Hello, I have not been able to find any directions on how to print a photo from a photo. I want to scan it and then have it printed on photo paper to give to someone for a copy. How do I do this? Is there a video that I can watch that will take me th...
I can not print from this printer nor does the ink levels show
It seems to have power, I removed all of the orange tape, but does not seem to be connecting to the network. I tried restarting the router and then turning on the printer while the router was rebooting, no luck. I've installed drivers on my devices a...
I keep getting an error code 24. How do I fix this or reset my printer so it will go away?
I can not get printer past it making annoying beep (1 beep) and then hearing/seeing scanner arm move a few inches and then it repeats. There is no error message. Just says Canon on screen. No obvious paper jams and ink is seated fine. Anyone please...
Subject | Author | Posted |
04-28-2024 12:33 PM | ||
04-27-2024 04:40 PM | ||
04-25-2024 07:00 PM | ||
04-25-2024 03:03 PM | ||
04-25-2024 05:02 AM |
