White Lines Through Text
I am seeing white lines through various lines of text. The lines are always at the same place regardless the font. I've cleaned and recleaned, aligned and realigned so many times I cannot count.Any suggestions?
I just bought the Canon Pixma Ts 3522 and I have used it several times to print things but when I try to scan it says their was an error. I read the drives needed to be installed/ updated so I went to the Canon website and downloaded the only drive...
I have a Pixma MG 2522 and got the ink absorber code and finally it stopped completely today. i did the reset with the pushing and holding buttons. Also it tucked the ink over the absorbers so you cant take it out. was able to do the reset and when i...
I have a brand new MB2120 inkjet printer. It was set up using wifi via router. From my desktop computer, I can print a plain text Word document. But when I try to print a page from a PDF that contains a color map, the printer just feeds through a ...
I know this will save power, but will it also induce extra printhead cleaning cycles and so cost extra ink? I have an MG5420 printer but I assume the answer applies to a lot of other Canon printers.
I have downloaded the latest drivers from Canon on my PC, but it still doesn't print any text, only pictures.If I combine text and images, it only print images. If I print an image of a text, it does print the image with text, black on white backgrou...
Hi, I have a Pixma TS9521C printer. It has started printing photos with lines (uneven coloration on the prinits in horizontal lines pattern). I have run cleaning, deep cleaning, print head alignment, but no help. What should I do to fix it? Thanks
I have a TR4720 printer. I recently in stalled new, genuine Canon ink cartridges, but I am getting an error code 1485.I tried to perform a reset of the printer. While the printer is on, unplug the power cord from the printer and let it sit for 60 sec...
Hi,I have a PIXMA G7020 that has started printing colors incorrectly. I saw another post which discussed a similar situation which didn't resolve with repeated deep cleaning and required a replacement printhead to correct the issue.My first nozzle c...
Recently I obtained a Canon MP270 (Pixima) and have been using it successfully for some weeks.Now, however, it will no longer print my Word Documents (usually 2 to 20 pages).It will print perfectly if I set it to 'Current Page'.But if I set: page 4-...
I've seen various versions & various dates attached to this information. I currently have a MX922 printer that the print head has gone bad ( I believe a B200 error). I've tried one version of a replacement head, however that was ineffective in fix...
Hi. I have a Canon Pixma iP8720 hooked up to a Mac running the Ventura and the printer had been performing just fine but out of the blue it stopped printing. All the Canon inks are new, the driver is up-to-date, I cleaned and deep cleaned the heads ...
Hi,I have been using a MG3600. I always find it time-consuming whenever i scan or copy multiple-page document since i have to manually flip it over. Is there a model that can automatically scan and copy both sides of a page without me flipping it? Al...
Chrome is a quarter size. Safari normal.
Subject | Author | Posted |
06-03-2024 09:43 PM | ||
06-03-2024 01:54 PM | ||
06-02-2024 09:42 PM | ||
06-02-2024 08:17 PM | ||
06-02-2024 05:31 PM |
