MF8380C multifunction - fax
How can I set up the fax to go to my email rather than printing out a page?Cathy
Right out of the box got error code 5011 when plugged in. Step #6 after removing all the packaging.Support says they are closed. Only thing I could find on line was a guy at Amazon had same issue and had to return his new unit. Anyone seen this be...
Canon MX860 says error B200. How can I fix it? Tried unplugging as it says and when I turn it on again the same error comes up. Please advise. Thanks
My new MF8380Cdw functions well when it is connected through USB. However, I have not made it to print/scan through wired LAN connection. I have tried on multiple HP notebooks with Win7 64-bit. I have tried turning Windows firewall off. I have McAfee...
How do you get the MX700 to scan from the top feed? I have all the latest drivers and software installed. When I put a sheet of paper in the top feed, it initiates the scan function when the switch is contacted by the paper, I select my scan setting...
My canon image runner 1023if stopped giving me a choice of duplex printing, once I switched to an IMac. Any suggestions on solving this issue?
I am trying to scan an image enlarged at high resolution and keep getting this message... "You are trying to scan an image exceeding 35 MB. Reduce image size or switch off the thumbnails view mode when you want to scan this image."I can not find any ...
Need help setting up PIXMA MG5420 with Windows 7 laptop.Thanks
Printer function no longer working. I've deleted and reloaded printer drivers, but installation fails when no printer is found.
I'm looking to get a good all-in-one printer-scanner set up that is compatible with Mac 10.6+, Lion, and Mountain Lion. Please list the compatible options. Thanks.
I need to buy a new printer for my home office. From a space stand point, the "all-in-one"printers are appealing, however I still need a good quality scanner. How does the quality of an "all-in-one" printer/scanner compare to a stand-alone scanne...
What is the life (number of pages) of a 220 black inkjet cartridge
Pixma 0700. Ink Absorbers almost full. How can I change them?
Does anyone know how to scan a picture when you have a mac?
paper jam alarm - there is no paper jam. It is a false error message. I have gone through the steps advised. Any other ideas?
Subject | Author | Posted |
06-09-2024 05:36 AM | ||
06-09-2024 03:31 AM | ||
06-08-2024 02:01 PM | ||
06-07-2024 03:20 PM | ||
06-06-2024 01:33 PM |
