Printer will not print after switching to window 8
My printer will not printer after switching to window 8
Not sure where the Serial Number is on my MP 460 Printer! several numbers on the bottom. None inside or on the back as the Canon site suggested.Any help would be greatly appreciated. Thanks! BobPittsburgh, PA
My Pixma MG3120 does not print, the print heads do not move, any suggestions?
My pictures are not printing. I've updated printer and drivers.run maintenence tests. Colors are printed from texts and black text was also printed. Any thoughts? Thank you for any help.
I can't see a scanner board to ask this question but....I have used my scanner lightly for a few years now the on off switches on & the bed lights up to initiate start up but then none of the scan buttons work. Help have I got a dud now??
my MP560 canon printer says: error has occurred, B200. Unplug power cord and contact canon
Connected with USB and have wireless set up. After sleep, printer will not print by USB unless I unplug the cable and plug it back in. But it will print wireless. I prefer printing USB because it is faster. The wireless setup is to print from other...
i lost my manual and have a B200 error on my MP620 cannon printer and would like to know how to fix it, thx?
Is it possible to set up the Mx 700 to scan wirelessly? I can print on a wireless network but I can't scan. I have an I mac with Lion. Thanks
Could you tell me how could I make working/install my Canon Pixma ip5300 inkjet printer on my Windows 8 laptop? Thank you George, Athens,Greece
When I go to system preferences and try to check under printers and scanners info I check under settings and I keep getting a message no information available.
Unable to scan from printer to pc
Help! PLS.. I am using windows 7. the printer dsnt work in my laptop (sony vaio) but its working in my husbands laptop (Asus) same OS. When i click print it will show the SEND FAX box.I install the printer twice already I did the first one and then ...
I tried everything suggested online to get rid of this error message B200 and nothing is working. I can't believe this printer is useless already..what else can i do besides turning it off and on, cleaning the printer contacts..and praying something ...
Subject | Author | Posted |
04-28-2024 12:33 PM | ||
04-27-2024 04:40 PM | ||
04-25-2024 07:00 PM | ||
04-25-2024 03:03 PM | ||
04-25-2024 05:02 AM |
