ip100
Seeking info on ease of use and durability of pixma ip 100 photo printer vs. others, particularly Epson 4x6-only Charm
pls help me with my canon printer pixma mx397...at first, it said that ink waste pas was full so i just clicked the ok button on the machine. but when i tried nozzle check or deep cleening, it said "Printer error has occurred. support code 5B02" how...
I have just bought a printer PIXMA MX455. Because my desktop has no WIFI, when setting up I chose USB connection rather than LAN. But I want to connect my laptops wirelessly so what do I have to do to achieve this?
I have a Canon Pixma mg3120. When I push the scan button, the response is E 3. And the scanner does scan. What does E 3 mean? How do I get it to scan?
brown prints pink. I'm using Canon Ink. Running Windows 7 64 bit. Doesn't matter what program I'm running. The one that really matters is when I'm printing labels on fabric sheets. It used to print great now the colors for the logo come out pink ins...
change color ink on printer, now printer will not recognize color ink. How do I reset the printer?
Has anyone found a solution to error 5011, esp. on the Pixma MX340?
mp360 printer shows "put in cartridge" with alarm light. Cartridges are in. Will print once then stop.Had the head cleaned and it printed out the nozzle pattern fine, Tried to print a page same alarm.
In addition to the GREEN light (which is always on when the unit is on), my Canon MP600 has the ORANGE light ON. (NOT flashing - just ON) It's stuck/locked up and the error message reads "The device may be incompatible. Remove the device and check t...
Are canon pixma mx452 and PIXMA MX459 the same?
I uninstalled the drivers, then ran the setup twice. Both with the same outcome. It finds the wireless network via the standard setup. I enter the wireless password, finds it fine. Then after I am finishing the setup via the CD I get the dialog t...
how do i cancel the "checking printer status" message that appears on bootup. It can sometimes take minutes to try to find one printer in the next room.
Is it true that Pixma MG 5220 cannot be installed on a PC with IE? I just tried to install the printer on my new laptop and that is the message that popped up.
Subject | Author | Posted |
04-17-2024 04:26 PM | ||
04-16-2024 09:57 AM | ||
04-15-2024 09:38 PM | ||
04-15-2024 05:20 PM | ||
04-15-2024 03:09 PM |
