Is it possible to copy a sheet with writing on both sides, not from the computer, but just a copy?
Hi! Is there anyway to prevent receiving unwanted faxes? Thanks
Anyone, I purchased a printer Canon MF 4880 a few months ago and the CD is missing. Now I want to add the printer to one of my new camputer for wireless access but I cannot find the software for this printer on the list of the printers on the web. ...
Thanks to the tips on getting scanning to work and how to clear out the lingering bits & pieces that prevented new driver install. Now I cannot print to the mf4890dw. Job shows up in queue, but I get "Error cannot print" and no useful information ab...
I have an excel spreadsheet with addresses and names. How do I output them using Word to my MX860 printer? One by one or as a group? How do I set up the paper options? Can I make the addresses a pretty color? I've never done envelopes, much less ex...
I am having problems installing this driver. I do not have the CD so I downloaded the driver from the website. the only instructions that i really saw just said to unplug the printer from the usb port before you run the driver install. I guess what ...
I've had a Canon MP560 for about three years now and it has been working fine. I've been regularly changing ink and performing the needed maintenance such as head cleaning, etc. For the past year or so, after I would replace the ink, the printer woul...
I inadertently purchased a couple of CLi 8R Red ink cartridges which were advertised as being compatible with the IP4200 printer. Then it dawned on me that this printer uses a CLi 8M Magenta cartridge. Are these cartridges usable or should I get ri...
Full black cartridge and will only print a little in yellow. Have printer the other day.
How do you print in black only (not color as I want to conserve color) on Pixma MG3520 printer.
My printer used to work well. No Airprint doesn't work. Acn no longer select duples. Can no longer select black and white or color. Using Mac Mavericks and lates Canon Driver and Firmware. Pleas ehelp.
I am trying to install cloud apps such as Fbook, Flickr but I get the error message - there are no apps available to register. My firmware is uptodate and I registered with PIXMA. Any ideas? Specifically, on the printer screen it even says: "Apps are...
One of the members here had printed a solution to fix the problem, & it worked. There is no solution printed in the Owners Manual. Thanks to the member who printed the solution.
04-18-2014 09:09 PMBought Canon Pixma MG6460 recently Needed Air printer for home network.. It works with my MacBook +MacBook Pro, iPad and iPhone., Was told I could connect it to my Desk Top (eMac) with USB but will not download even thouggh Ive...
Subject | Author | Posted |
04-29-2024 10:49 AM | ||
04-28-2024 12:33 PM | ||
04-27-2024 04:40 PM | ||
04-25-2024 07:00 PM | ||
04-25-2024 03:03 PM |
