Is there a way to print a single page(color other than white) without loading it in the cassette tray? Some printers will allow to place a single page in the top feeder and have it fed when you print.
How do I change the input keypad from alpha to numeric on the MX922?
Tried to print out a paper and in the print que it just says Printing forever. it actually never prints. nor will a test page print. Currently using Windows 7 and everything shows as the print is connected and working properly. http://i.imgur.com/s1...
Part of my document feeder tray on my ImageClass D480 snapped off. I need to replace it. So, I ordered the part for less than 20 from Canon. However, I noticed just now there's no simple way to unattach or reattach it. I called Canon tech support and...
I've had a fairly longstanding issue with my 4-yr old Pixma - it prints A4 and even A5 fine in any quantity but as soon as I ask it to print A6 (6 x 4) or square (custom) sizes it will only print at most 2 before deciding to quit - instead it draws t...
MX450 wireless LAN setup error say network key is incorrect or does not correspond access pt Have been trying to connect a MX450 multi function printer to my wireless LAN since I purchased it in Feb 2014. My setup is: HPdesktop WIN7 (64); connecte...
A telephone mini usb cable fed into the rear paper tray and appears to be lodged at the point where rear and front loaded paper enters the print chamber. Is there a proceedure to get access to that point? I can see it but it is not reachable by rem...
how fix blank lines on scans using MF5770. Already restarted Win 7 computer and MF5770. Using Windows fax and scan. Several months of successful use before this problem began last couple weeks. 9/2014 Thnks for any help
Everytine I try to print from my Mac if get the message that my printer is offline/not connected. How do I remedy this?
My MX890 does not print the black ink both of which are adequately full. 2 of the color cartridges say low, but not empty. I cannot read the message when it prints. What can I do?
iP2700 on Win 7 won't print:- documents to be printed appear in print cue- top item in print cue shows "printing"- green lite on printer is blinking-"re-starting" document in printer cue produces no results.- computer is on a home network- will not p...
My imageclass Mf8380 Cdw when copying, scanning or faxing through the document feeder makes a vertical line on the paper. I have tried cleaning the feeder but it hasn't stopped the problem. When copying from the glass directly there are no problems...
Subject | Author | Posted |
04-23-2024 02:15 PM | ||
04-23-2024 08:22 AM | ||
04-22-2024 09:31 PM | ||
04-22-2024 07:23 PM | ||
04-22-2024 04:35 PM |
