When I originally installed my MX320 in Windows Home Premium, I installed the Solution Menu and successfully used it to scan documenets and save to files on my computer for several years. After my mother board self-destructed, I assembled a new compu...
I have just replaced the printer cartridges and now when I print I get a blank page like this. Once I print the same page again it is fine...how do I correct this?
my ink was still full when it quit printing so i changed ink twice and still wont print. the ink z good
Hi could someone help me how to scan multiple pages from my PIXMA MG 5520 as a PDF format into a folder on my pc?I only managed to get .JPG format selected and only one page scanned at a time.Thanks
how do you set up the fax?
How can I do a hard reset for my PIXMA mg6150? Does anybody know?
Just unwrapped brand new printer mg7150The very 1st message was 6000 error messageAll sticky tape etc removed. No paper even loaded but got the message paper was stuck! Unplugged several times and tried againGot a bit furtherPut in print cartridgesPu...
Recently my printer has begun printing with even horizontal lines across the whole page. I've tried cleaning and deep cleaning, but neither have fixed the problem. Attached is the print nozzle check pattern: http://i.imgur.com/JrLZWgN.jpg . You can s...
I have the same problem as Lonnie but the solution you provided does NOT work for me. No matter where I go under Preferences, Drivers, etc. I see no drop down box for 2-sided printing. The printer device gives me no options for double-sided printi...
Have tried printing from IPhone, IPad, PC and lap top. Sounds like it is printing but pages are blank.
My Canon MG8120 won't print wirelessly from my MacBook Pro through a D-Link DIR-820L 15 feet away. Can print to any HP in the office, but not to the three different Canon printers. Running OS 10.9.5 (Mavericks) on the MacBook. Page will start to p...
I also have the mx 822.. it does NOT auto append the date, i do not need the date and 0001 saved on each document. Please tell me this can be turned off. I have looked through all the settings in the 'Quick Menu' which to be honest.. also bums be out...
Trying to copy/print a multiple page document; maybe it can't be done on this simple printer but seems I should be able to load multiple pages to be copied in the back loader and have it print from the internal paper supply?
Subject | Author | Posted |
04-25-2024 05:02 AM | ||
04-24-2024 11:04 PM | ||
04-24-2024 10:47 PM | ||
04-24-2024 10:59 AM | ||
04-23-2024 09:51 PM |
