Search instead for
Stickers won't print correctly
Dumbassprinter
New Contributor
I just bought a tr7520 pixma printer. I tried printing 2" stickers and it prints all way at the top and not in formatted print area of the sticker sheet. If I print them on plain paper, they print as fomatted. They only go off the format when I try to print them on the sticker sheet.
Is there a setting I need to change some where to get them to print properly? I use an iMac desktop. The printer is connected with a cable, not via wifi.
Dumbassprinter
New Contributor
So thanks for all the no answers or suggestions. I figured it out myself. For anyone elsewho may be having the same issue here is the answer -
Use the rear feed tray. It will keep the label sheet formatting and print your labels in the label print area.
1 REPLY 1
Dumbassprinter
New Contributor
