04-07-2016 09:46 AM
MX922 was working perfectly and I love this printer. A few days ago, it failed to print an on-line tax return. Assumed there was some problem with the web site so I just saved it as a pdf. Then it happend again...prints color fine but nothing in black. Nozzle check/test page is perfect but did a cleaning anyway. Still the same. Happens with most WORD documents but one I created 4/5/16 will print--one I created 4/6 will not. So far all Acrobat & html docs are affected. Have deleted and added printer but that did not help. I have never been able to use as wireless so it is plugged into USB.
OS MAC el Capitan. Recently installed Family Tree Maker and perhaps an MS Office update.
Will appreciate any suggestions.
04-09-2016 08:38 PM
Thank you for your reply. You are correct...I did not realize there were supposed to be two black grids on the test page. I called tech support and we are working on it.
04-07-2016 09:54 AM
Forgot to add that it will also not copy a document from glass when I select "black" but will copy if I select "color" but not a good copy.
04-09-2016 09:23 AM
Hello.
Double check your latest nozzle check printout to confirm whether or not the PGBK grid is printing at the top of the pattern. It should be above the two cyan bars.
If the grid is missing, try performing 1-2 deep cleanings to see if this will help.
If you continue to have difficulties with this issue, find more help at Contact Us.
04-09-2016 08:38 PM
10-14-2017 08:02 PM
12-07-2017 04:04 AM
Horrible online support and horrible printer functionality. If it prints black on the test page next to the colors, it should be able to print black on a non-test page.
Im having the same problem. It prints 3 rows of different shades of fblue, 3 rows of different shades of red, 1 row of yellow, then 1 row of black. To the left of all of these 8 rows, it prints diffferent shades of gray-black. Above the 3 rows of blue, it very faintly prints some black, so faint, that its almost nothing.
It seems that this problem is not a bug, but a feature.
03-10-2021 12:00 PM
11-15-2020 08:20 PM
04-22-2021 05:25 PM
The deep cleaning fixed it for me too!
04-09-2017 06:49 PM
try to use a online test page generator like printertestpage.org
