08-16-2021 04:43 AM
Since I purchased this printer, (and have had it for many years), the printer has always defaulted to Copy mode on the printer display. I had recently sent a couple of faxes. Now, the display defaults to fax mode. if I click on the copy button, it does switch to Copy mode. But, if I don't do anything on the printer for 3 minutes, the printer display will switch to fax mode.
I don't know what I did to cause this, but I would like to have the printer to set Copy as the default mode again.
FAX line has been disconnected. FAX memory is empty.
Printer is connected wirelessly to a windows laptop, and wired to an Apple iMac. (this should not be an issue)
I can print from the laptop and the iMac without issue.
How do I fix this?.
10-12-2021 03:41 PM
