09-25-2014
01:04 PM
09:40 AM
I have a Cannon MX922, i am getting code "5011" cancel printing. Turn off and plug in, if problem persist call support. I did so and i am asking for help. did not work.
11-02-2017 11:31 AM
AnnP,
Troubleshooting with our support group will be needed to narrow down the cause of your issue. Please contact our support group using the "Contact Us" link below for additional assistance.
09-25-2014 01:09 PM
Hi ashbyv!
Thanks for posting in the Canon Forum! The Forum is not intended for immediate help, but a place to allow for the Community to give you assistance and feedback. If this is an urgent support need, please CLICK HERE to reach our friendly Technical Support Team.
Thanks!
09-25-2014 01:14 PM
CAn you tell me what it could possibly mean? I have looked for paper jams and no luck there. I have contacted support and waiting on them to email me back. Just thought maybe i could get a jump start. Also, may i ask, the lights on the cartirdges are they suppose to be on at all times when printer is turned on? Thanks for your assistance.
10-14-2014 01:26 AM
Hi ashbyv,
The lights on the ink tanks in the printer should be lit when the printer is turned on. The 5011 error is a general hardware error; since you have already verified that there are no paper jams in the printer, with a flashlight or other bright light, please check the paper feed and print head areas of the printer to verify that there are no other obstructions in the printer that may be causing the error. Once this has been done, if you reset the printer and still reeive the same error, it will require servicing. Please call or email us at one of the methods on the Contact Us page to obtain your servicing options.
06-13-2017 06:36 PM
Thank you....this worked for me when I was just about to bin it !!![]()
09-26-2017 03:41 AM
09-27-2017
05:33 PM
05:45 PM
SamanthaW
It got me out of the error code but my pc won't recognize the printer. When I turn off the printer, it will not turn on anymore. I have to unplug the power cable and plug it back in to power on the printer but the error code comes up again.
Edit: I fixed it by opening the ink cartridge compartment cover. [Removed link to 3rd party per Forum Community Guidelines]
09-29-2017 07:24 PM
Brilliant, tried everything and was about to use it as a missile until I read your solution. To my surprise it works perfectly again, a thousand thanks. How on earth did you come up with that solution?
09-30-2017 11:59 AM
Hey I did this and now the printer will not turn at all. Nothing.
11-02-2017 11:31 AM
AnnP,
