04-19-2018 02:56 AM
Hi everyone!
I would just like to ask if anyone knows how to fix ADF of G4000. The printer does not accept documents to copy or scan using the ADF
Thanks!
04-30-2018 06:45 PM
Hi jaims,
To scan a document at optimum quality, load it on the platen glass. If you prefer to use the document feeder:
Make sure that any original has been removed from the platen glass.
Open the document tray.
Insert the document in the document tray until you hear a beep sound.
Load the document WITH THE SIDE TO SCAN FACING UP in the document tray.
Note
For details on the supported originals, see below.
When you set the alarm to be silent in Sound control of Dev. user settings, the alarm will not beep even if the document is inserted in the document tray.
Adjust the document guide (A) at the front of the printer to match the width of the document.
Do not slide the document guide too hard against the document. The document may not be fed properly.
This didn't answer your question or issue? Please call or email us at one of the methods on the Contact Us page for further assistance.
