03-29-2024 12:03 AM
My printer was working fine but all of a sudden it started printing my pictures really bright like someone turned the brightness up on a screen. The black is also coming out slightly green
I’ve tried to manually change the intensity but it only helps it a little bit.
Ive done a nozzle check and the colours are bright. GY doesn’t even show.
03-29-2024 07:27 AM - edited 04-01-2024 12:49 AM
Hello,
I can see your post and I give you some ways to find your solution please see below and follow the information.
It sounds like your printer is experiencing a color balance or ink cartridge issue. Here’s what you can do to troubleshoot the problem:
If these steps don’t resolve the issue, it may be a hardware problem, If you want more info please tell me I am happy to help you.
Best Regard,
ryan1969
Hello,
Best Regard,
ryan1969
03-29-2024 09:43 AM
Until you can get a proper nozzle check it is a waste of effort trying to adjust how the printer is outputting.
If three or more deep cleanings don't produce a correct nozzle check you likely have a print head or internal problem.
03-30-2024 01:53 AM
Thank you! After multiple deep cleans and a driver update it started working correctly again.
03-30-2024 06:39 AM
Glad you got it working. The Pro-100 is a great printer. I have had mine for over 10 years.
Two hints:
1. Don't turn the printer off using the power button. Use the Auto Off/On settings. It will save ink because it won't go through the large startup ink purge.
2. Run a nozzle check every two or three days. It won’t use much ink and it will prevent clogs.
