CP1300 Blank Strip
CaptAl
Printing a landscape print (tear-off on L/R).  Top and bottom of image are fine but there's a 1.7" blank strip running across the image.  Tried with a new ink cartridge - same results.  Suggestions?P1030684.JPG
rs-eos
Are you using Windows? If so, this link should helpCanon Knowlege Base.
Ricky
Camera: EOS 5D IV, EF 50mm f/1.2L, EF 135mm f/2L
3 REPLIES 3
rs-eos
Ricky
That did the trick!  I went to Windows Update and just installed everything available.  Selphy is now working the way it should - the wife is thrilled and I didn't have to buy a new printer.  THANK YOU!
Excellent! Glad that was the fix.
Ricky
