01-23-2024 08:32 PM
My camera is a canon G7X Mark III. When I record myself with it individually, I don't have any noticeable grain and the video quality is quite nice. However, when I try to use my camera as a webcam using the eos webcam utility software, I get noticeable grain. Keep in mind, that I used the same background, lighting and same time of day so I doubt it would be that. I experimented with lighting to see if this could be a possible issue but it doesn't seem to make a difference. I also looked at ISO and Aperture but for these things, I don't know if I am doing anything wrong.
Also, my setup for using my camera as a webcam is plugging a usb c adapter from the camera to my laptop.
01-23-2024 10:06 PM - edited 01-23-2024 10:07 PM
Hi Otto and welcome to the Forum:
Have you considered that your cable is generating the noise in your image? Have you the means to use another cable and another port into your computer? It might well be worth checking those out.
(BTW 'grain' is a characteristic of film because of the chemistry, so noise is the correct term for digital).
01-23-2024 11:13 PM
I have tried another cable and I have looked in the manual as well. The cable switching didn't work.
01-23-2024 11:43 PM
Thanks for that response. Do you have another port in the computer into which you can plug the cable? Just trying to eliminate every element...
01-24-2024 03:25 AM
Yeah I have tried different ports but they unfortunately don't make a difference.
