EOS Utility software not opening
Desmiddyac
I was using eos utility tethered to my computer Windows 7 and Windows just stopped working and re booted itself. When I clicked on the Utility icon the software failed to open giving an error message "Eos utility has stopped working. A problem caused the program to stop working correctly. Windows will close the problem and notify you if a solution is available" I uninstalled the utility program and reinstalled it but still get the same message. I have repeated this several times over several days but still the problem exists. I have used this software for months without any problems until now. Does anyone have a solution?
1 REPLY 1
Blightyguy
You could try doing a system restore on the pc because likely there has been an update the software didn't like worth a shot
