Search instead for
EDSDK Handler for take pictures
Lucinda28
New Contributor
I am trying to create a Program for my Canon EOS Rebel T7, but when I try to send the command EDSDK.EdsSendCommand(CamConn, EDSDK.CameraCommand_TakePicture, 0) the program returns the error EDS_ERR_INVALID_HANDLE, how I can add a proper Handle for taking pictures?
Thanks!
Print of code here
2 REPLIES 2
Waddizzle
VIP
These forums are intended to provide support to end users of Canon products, not software developers.
I know nothing about the EOSDK, but I do know programming.  As far as your issues goes, I view it as similar to a car not running because you did not put gas in the tank.  You probably need to call GetHandle prior to making that method call.
kvbarkley
Honored Contributor
And if you *did* call InitHandle or GetHandle or whatever it is called, you need to check to make sure you get a valid handle - probably anything but NULL - before you do any other calls.
