Reply
Highlighted
New Contributor
Re: where is the WPS button?
You are a genius!  I am so grateful for your post. This printer drives me nuts!  Thank you thank you thank you !!!
Highlighted
Occasional Contributor
You are welcomed. it is actually quite a good printer (except for being a major print-alcoholic) and maybe Canon will eventually hire some documentation "interpreters" to translate what their documentation writers produce. Until then...our posts here do help each other.
Highlighted
hope you read further to discover hitting "stop" button will bring you up another alternative as many of us finally discovered who are also without a WPS button
Highlighted
Another victory! Glad you succeeded.
Highlighted
New Contributor
Thank you so so much...trying since two days..worked in seconds
Canon should hire you
Highlighted
Good to hear you succeeded!
And...yes, I know. Canon seriously needs to:
1. Hire & USE user interface talents
2. Invest in common-send and visually-oriented manual documentation creators
Meanwhile, we have to remember with no such "button" the STOP one right on the printer will bring up the menu section we need. If the printer mysteriously loses the connection go back to the setup menu & hit STOP button again. Mine still does with each system update.
Highlighted
New Contributor
WPS (Wireless Protected Service) is located in your wireless router. Press and hold for a few second and go back to your printer, then press OK on printer. It will set up the wireless on the printer. Ofcourse if you dont have wireless service, you can not activate it.
Highlighted
Many of us do not have a WPS button on our router.
Highlighted
New Contributor
thank you! great answer and it worked! Kudos!
Highlighted
Yeah! Another success! Glad it worked for you.
powered by Lithium
