10-09-2015 11:59 PM
Is there no way for this unit to save the wifi security info of my aircard? everytime I start up printer, I have to re-install the security code. Obviously I don't want to keep printer running all day, but I use it 5 - 8 times a day. If no solution, maybe someone knows of a unit that can store security info, so it will auto connect to network.
Thanks,
Alan
10-12-2015 08:30 AM
Hello.
We cannot guarantee communication with the use of a mobile device such as an air card or hotspot. A standard Wi-Fi router should be used in order to use the printer wirelessly.
If you continue to have difficulties, consider using a USB connection with your Windows or Mac OSX computer in order to print while on the road.
10-12-2015 08:44 AM
My whole purpose of this printer was to print from my tablet. I'm not going to intsall a router in my van, to print invoices and I only turn on printer when I need it. You are saying this printer is the wrong one for this type of application? Please let me know ASAP, so I can return it. Thought there would be a work around.
Thanks,
Alan
10-12-2015 10:17 AM
Hello.
A standard Wi-Fi router would be needed in order to use the printer on a network.
If you need additional assistance, find more help at Contact Us.
