06-12-2017 06:07 PM
Wow; that's an excellent tip about resetting your router via software, Wkothman! I always rest mine via the unplug/plug method, but I'm gonna try that to see whether it soloves some other problems.
(Meanwhile, my MG5420 has been driving me crazy with a "the cover is open" message; I've been tearing my hair out over that for two months now. At first, I was screaming "No, it's NOT!" at it, but recently discovered that there's more than just the obvious top cover, and that sometimes, the message refers to a non-obvious cover I haven't been able to find yet. 😕)
At least someone uses AirPrint happily! (You sure we're lucky the storm didn't zotz your equipment altogether!)
01-13-2018 08:26 PM
I'm trying to connect a canon MX926 printer to an iphone 6 but I still get the message 'No Airprinters found' I followed your instructions to enable the bonjour setting but I was unsure of where the home button was- I ended up pressing the ;menu' buttion but I still get that message 'No Airprinters found'' Any help would be greatly appreciated, David
02-05-2018 03:03 PM
Thank you, Ramona -- I am also not an "average" user -- not only have I owned Apple products since 1985, I worked in academic IT for seven years and have set up labs of the things.
I hadn't thought to check "Other/Bonjour" settings to enable printing from my iPhone. Excellent call! That fixed my troubles.
02-05-2018 03:06 PM
dnortons -- I also just pressed the "menu" button after enabling Bonjour, and it worked fine. That's not what's breaking down in your fix. Once you've enabled bonjour and hit "okay," the menu button is fine.
Nothing on my end required rebooting, but your mileage may vary. Verify that you can still print from your computer to your printer; if that doesn't work, then the bonjour setting was not your only probem. Good luck!
05-03-2018 10:26 AM
Hello.
If communication issues persist, troubleshooting with our support group will be needed to narrow down the cause of your issue. Please contact our support group using the "Contact Us" link below for additional assistance.
06-12-2018 12:34 AM
