02-23-2015 11:56 AM
03-05-2015 03:09 AM
Hi BinkyM,
You will want to ensure that the Bonjour setting on the printer is enabled. If the setting is disabled, you will not be able to print via Apple AirPrint. To ensure the setting is enabled, please follow these steps:
1. Navigate to SETUP from the main screen of the printer.
2. Press the third Function button below the screen to display the SETUP menu.
3. Use the left/right arrows to select DEVICE SETTINGS, then press the OK button.
4. Use the up/down arrows to select LAN SETTINGS, then press the OK button.
5. Use the up/down arrows to select OTHER SETTINGS, then press the OK button.
6. Use the up/down arrows to select BONJOUR SETTINGS, then press the OK button.
7. Use the up/down arrows to select ENABLE/DISABLE BONJOUR, then press the OK button.
8. Use the up/down arrows to select ENABLE, then press the OK button. The printer will enable the setting and then
display a confirmation screen showing that it was set.
9. Press the HOME button to return to the main menu.
Should you still experience difficulty after enabling the Bonjour setting, please call or email us using one of the methods on the Contact Us page for further assistance.
02-23-2015 02:47 PM
Is your printer connected to your Mac by USB or WiFi?
03-03-2015 08:13 AM
03-03-2015 11:02 PM
03-03-2015 11:09 PM
03-04-2015 07:34 AM
Go here and see if this helps:
03-04-2015 08:31 AM
03-04-2015 08:57 AM
03-04-2015 11:46 AM
03-04-2015 11:47 AM
